lpl0an
Reboot automacticly at midnight
Wed Mar 27, 2013 7:36 pm
I'm trying to make my RPi reboot everyday at midnight. I set a crontab :
0 0 * * * reboot
but I looked in the syslog file, and it doesn't reboot apparently. Do you have any ideas why ?
Thank you for your answers.
Re: Reboot automacticly at midnight
Wed Mar 27, 2013 7:58 pm
Try putting in the full path of the reboot command: /sbin/reboot
Also, you are puttin this in the root crontab, aren't you? The pi user doesn't have permission to use the reboot command unless with sudo.
lpl0an
Wed Mar 27, 2013 9:58 pm
How do I know I'm on root crontab ? I'm root whan I type :
crontab -e
joan
Wed Mar 27, 2013 10:02 pm
As the previous poster said, change reboot to /sbin/reboot in your crontab. Crontab needs the full path to commands.
ant_thomas
Wed Mar 27, 2013 10:36 pm
lpl0an wrote:How do I know I'm on root crontab ? I'm root whan I type :
crontab -e
You should be in the correct crontab but you can access the root crontab by typing
sudo crontab -e
There is a root crontab (accessed by using sudo) and user crontabs.
lpl0an
Thu Mar 28, 2013 5:07 pm
It works perfectly !
sudo crontab -e
then edit the file adding the line :
0 0 * * * /sbin/reboot
Thanks !
