Wed Mar 27, 2013 6:24 pm
mulluysavage wrote:
I am running Ubuntu, and found a VNC client in the Ubuntu Software Center - gtkvncviewer. The one they use in the lesson is RealVNC. I enter the info just as they do in the Lesson with RealVNC - appending with the port and everything, and user: pi password: raspberr, and get "you have been disconnected."
FWIW I've used tightVNC client/server on Ubuntu with a Pi and got things working O.K. I used a couple guides from the wiki (
http://elinux.org/RPi_Guides). If you havn't already done so you might like to give PuTTY a try too - gives you a ssh login that supports X11 forwarding - some screen-shots of suggested setups are in my webpages at
http://www.cpmspectrepi.webspace.virgin ... aspPi.html .
Trev.
