lpl0an
Problem MYSQL Install
Tue Mar 26, 2013 7:36 pm
I have a problem installing MYSQL. I launch installation :
apt-get update
apt-get install mysql-server
I begins OK but then I've got the screen asking me to set a root password. I type it, confirm and then it tells me it couldn't configure the password etc and it quits.
I may be that I've already installed it, but i'm not even sure ! I've got Owncloud installed I don't know if it uses MYSQL...
If you have some ideas or solutions or questions...
Thank you for your answers.
tonyhughes
Re: Problem MYSQL Install
Tue Mar 26, 2013 8:13 pm
dpkg -s mysql-server
Will tell you if you have that particular package installed.
Or, uninstall and start from scratch:
sudo apt-get --purge remove mysql-server -y && sudo apt-get update -y && sudo apt-get install mysql-server -y
DeeJay
Tue Mar 26, 2013 8:18 pm
Similar problem discussed and resolved here - http://raspberrypi.stackexchange.com/qu ... l-raspbian
How To Ask Questions The Smart Way: http://www.catb.org/~esr/faqs/smart-questions.html
How to Report Bugs Effectively: http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
lpl0an
Thu Mar 28, 2013 6:00 pm
I tried to reinstall mysql from a backup wich hasn't got it. The installation works fine, until this :
Image.
Then I put OK and then :
I don't know what I can do...
bigamito
Wed Jul 24, 2013 3:02 pm
I've the same problem...
Have you solved them?
hamdy.aea
Fri Dec 02, 2016 11:22 pm
I have the same problem :
Processing triggers for systemd (215-17+deb8u5) ...
mysql-server-5.5
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@raspberrypi:/run/mysqld# systemctl status mysql.service
● mysql.service - LSB: Start and stop the mysql database server daemon
Loaded: loaded (/etc/init.d/mysql)
Active: failed (Result: exit-code) since Fri 2016-12-02 20:58:31 UTC; 5min ago
Dec 02 20:57:51 raspberrypi mysql[13662]: /etc/init.d/mysql: WARNING: /etc/mysql/my.cnf cannot be read. See README.Deb...ning).
Dec 02 20:57:51 raspberrypi /etc/init.d/mysql[13672]: WARNING: /etc/mysql/my.cnf cannot be read. See README.Debian.gz
Dec 02 20:58:31 raspberrypi /etc/init.d/mysql[14121]: 0 processes alive and '/usr/bin/mysqladmin --defaults-file=/etc/m...ed in
Dec 02 20:58:31 raspberrypi mysql[13662]: Starting MySQL database server: mysqld . . . . . . . . . . . . . . . . . . ....ailed!
Dec 02 20:58:31 raspberrypi systemd[1]: mysql.service: control process exited, code=exited status=1
Dec 02 20:58:31 raspberrypi systemd[1]: Failed to start LSB: Start and stop the mysql database server daemon.
Dec 02 20:58:31 raspberrypi systemd[1]: Unit mysql.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.
root@raspberrypi:/run/mysqld# systemctl status mysql.service -l
Active: failed (Result: exit-code) since Fri 2016-12-02 20:58:31 UTC; 6min ago
Dec 02 20:57:51 raspberrypi mysql[13662]: /etc/init.d/mysql: WARNING: /etc/mysql/my.cnf cannot be read. See README.Debian.gz ... (warning).
Dec 02 20:58:31 raspberrypi /etc/init.d/mysql[14121]: 0 processes alive and '/usr/bin/mysqladmin --defaults-file=/etc/mysql/debian.cnf ping' resulted in
Dec 02 20:58:31 raspberrypi mysql[13662]: Starting MySQL database server: mysqld . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . failed!
Hamdy Abou El Anein
Hamdy Abou El Anein
