awpatel
On Boot says Read-only File System
Sat Mar 23, 2013 7:14 pm
Just installed the lastest Raspbian Wheezy on the SD Card and am trying to use Raspberry. When I boot it gives me the raspy-config screen. Whatever option I choose, fails due to the file-system being read only. Why is this? I have checked the directory settings and they do have write permission for Root. What is the password for Root and how do I get things to work.
I cannot even create a file under the "pi" account due to swap etc not being available.
Thanks.
AWP.
mahjongg
Re: On Boot says Read-only File System
Sat Mar 23, 2013 7:28 pm
I can only imagine that something went wrong while creating the image on the SD-card.
FTrevorGowen
Sat Mar 23, 2013 7:53 pm
Could it be that the SD card's tiny (often white) lock slider/switch is getting pushed into the "locked" ie. read only position during insertion? IIRC from the wiki, this has be reported as happening with some (makes of) cards.
Trev.
mahjongg
Sun Mar 24, 2013 3:37 pm
true, but unlike RiscOS, which actually can run completely from RAM, and can thus unlock the SD-card so it can be replaced by another one. All versions of Linux do not have that ability, and so completely ignore the write protect switch.
jojopi
Sun Mar 24, 2013 3:54 pm
All operating systems for the Pi ignore the write protect switch on the system SD card. Because the wires from it are not connected to the SoC.
awpatel
Sun Mar 24, 2013 4:08 pm
Hi All,
Thanks for your replies. The SD card I am using is a DANA ELEC High Speed, 4GB, SD Card. I had to put the Lock switch in the Lock position instead of the unlocked position. Once that was done it all worked fine. Not sure why, but it now works.
AWP.
mahjongg
Mon Mar 25, 2013 1:22 am
jojopi wrote:All operating systems for the Pi ignore the write protect switch on the system SD card. Because the wires from it are not connected to the SoC.
True, I was actually talking about the card insert switch, sorry for the confusion.
