Shikky wrote:Same here, I registered so I could create a thread, but then I saw yours.
I can't get neither the gpu_mem nor the gpu_mem_512 to work. The other settings in config.txt work fine (overscan, sdtv_mode, etc). Seems like bootcode.bin doesn't correctly do it's job somehow.
As far as I know, I'm at the latest firmware version (the one from 5 days back). 3.6.11+ kernel.
Generally I would say pick an older version, but bootcode.bin is already a month old, so it should not be a 'new' bug or something (unless its in start.elf).
Well, I've rewrite the img using windows image writer, update the firmware using "pacman -Syu" instead of "rpi-update".Now everything goes fine with me.I guess the problem is the rpi-update script.
BTW, if I don't need the graphics,how small the gpu_mem can be set to use the memory as little as possible to max the memory used by ARM?
Sorry for my poor English.
