sristi194
RTL2832u in Raspberry
Fri Mar 22, 2013 4:09 am
Hi I am trying to receive FM using RTL2832u SDR in my Raspberry Pi,
The OS in my raspberry is RASPBIAN WHEEZY and I have used the following commands to install the necessary drivers to the system
sudo apt-get install git
sudo apt-get install cmake
sudo apt-get install libusb-1.0-0.dev
sudo apt-get install build-essential
after which I downloaded and installed rtl-sdr using the following commands
git clone git://git.osmocom.org/rtl-sdr.git
cd rtl-sdr/
mkdir build
cd build
cmake ../
make
sudo make install
sudo ldconfig
then I copied the rtl-sdr.rules to the directory /etc/udev/rules.d
when i tried to copy using cp command its not copying, hence i used sudo cp to copy the corresponding file
after this i tested using rtl_test -t
the device is not getting detected
but when i use the command lsusb
it is showing that a device of Realtek Semiconductor Corp. is connected
Can anyone help me to solve this problem???
woodpecker
Re: RTL2832u in Raspberry
Sat Mar 23, 2013 5:13 pm
Which dongle are you using, RTL2832U plus Elonics E4000 tuner works fine for me, I am using the Pi as a wireless AP streaming the data to SDRSharp on a tablet.
The output of rtl_test -t should find a device then check the tuning range like this:-
Found Elonics E4000 tuner
Supported gain values (14): -1.0 1.5 4.0 6.5 9.0 11.5 14.0 16.5 19.0 21.5 24.0 29.0 34.0 42.0
Benchmarking E4000 PLL...
[E4K] PLL not locked for 52000000 Hz!
[E4K] PLL not locked for 2209000000 Hz!
[E4K] PLL not locked for 1105000000 Hz!
[E4K] PLL not locked for 1251000000 Hz!
E4K range: 53 to 2208 MHz
E4K L-band gap: 1105 to 1251 MHz
sristi194
Sun Mar 24, 2013 2:51 am
Thanks for your reply, I am using DVB-T-DAB-FM stick, yesterday i found that there is no sound card driver in my pi so i installed it using
sudo apt-get install alsa-utils
Can you just mail me all the steps/commands which you followed so that I can try them and check whether its working on my pi
My raspberry is MODEL B and I am using is DVB-T-DAB-FM dongle
DrPiD
Mon Jun 03, 2013 10:16 am
This might be a little late but I've just had the same experience, I started with the commands you followed and my device wasn't being detected by the rtl_test command.
# Install dependencies
sudo apt-get update
sudo apt-get -y install git cmake build-essential libusb-1.0 qt4-qmake libpulse-dev libx11-dev
# Fetch and compile rtl-sdr source
mkdir -p ~/src/
cd ~/src/
cd rtl-sdr
mkdir build
cd build
cmake ../ -DINSTALL_UDEV_RULES=ON
make
sudo make install
sudo ldconfig
I started again and followed the above instructions for the build stage, then moved the rules file. I rebooted my pi and it worked.
Hopefully this helps?
Community Manager - IndieCity
P_Monty
Fri Jun 01, 2018 9:08 am
Sorry to dig up an old thread, but this is kind of where I'm at.
I went through the process detailed by the OP, but when I run rtl_test, I get:
"Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2832U OEM
Kernel driver is active, or device is claimed by second instance of librtlsdr.
In the first case, please either detach or blacklist the kernel module
(dvb_usb_rtl28xxu), or enable automatic detaching at compile time."
Can anyone tell me what this is trying to tell me and what I need to do to fix it please.
Paul
Fri Jun 01, 2018 10:07 am
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
P_Monty
Fri Jun 01, 2018 11:21 am
Thanks.
That got the server running - now for the next step :-)
Fri Jun 01, 2018 5:35 pm
I got mine running Breeze FM (107.6FM) and as an ADS-B flight tracker this afternoon.
The ADS-B stuff is at https://github.com/MalcolmRobb/dump1090 the hard part was getting the ../public_html folder from that git clone into the right place (/usr/local/bin/public_html/*) after I built & moved the dump1090 program to /usr/local/bin/dump1090.
P_Monty
Fri Jun 15, 2018 6:09 pm
Gaghh I'm stuck again...
rtl_test finds the device and gives some useful information about it.
rtl_tcp -a gives:
"Found 1 device(s):
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
Tuned to 100000000 Hz.
listening...
Use the device argument 'rtl_tcp=192.168.1.114:1234' in OsmoSDR (gr-osmosdr) source
to receive samples in GRC and control rtl_tcp parameters (frequency, gain, ...)
So far, I haven't been able to connect sdr software on my mac to it (cutesdr or sdrdx) - they both refuse to find the sdr in the network settings.
So, either
a) I've totally mis-understood and this was never going to work
b) I've got some basic setup wrong
c) There's some network issue stopping the two communicating (the mac can ping the pi)
To help with the faultfinding, an someone recommend a simple sdr client I can run on the pi (its a pi2 if that makes a difference) just to prove the server functionality
Many thanks
Paul
Fri Jun 15, 2018 6:39 pm
Before I turned my RTL-SDR into a Piaware ADS-B receiver I was playing with https://airspy.com.
Running SDR# on Windows connecting to the SDR running on my Raspberry.
https://www.rtl-sdr.com/rtl-sdr-tutoria ... n-rtl-sdr/
It's currently feeding ADS-B/S-Mode/MLAT stuff to https://flightaware.com/adsb/piaware/build
IrishKing84
Fri Aug 03, 2018 2:34 am
I am having a similar issue I get the following:
Found 1 device(s):
Supported gain values (29): 0.0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6
Sampling at 2048000 S/s.
No E4000 tuner found, aborting.
any feedback is appreciated!
