andrewstillie
Can anyone help me fix WiFi connection on wlan0
Thu Mar 21, 2013 10:15 pm
I am relatively new user with the pi.
I have just installed tightvncserver, after my next reboot I have been unable to connect wirelessly.
When I run the if config command I can only see eth0.
When I run lsusb I can see my wireless adaptor listed.
Can anyone offer some help?
Andy
docwisdom
Re: wlan0 not listed when I do ifconfig
Thu Mar 21, 2013 10:17 pm
is wlan0 setup in /etc/network/interfaces ?
andrewstillie
Thu Mar 21, 2013 11:32 pm
Yes, that is set correctly and unchanged from prior to the reboot.
Joe Schmoe
Thu Mar 21, 2013 11:54 pm
The most important thing is to do "ifconfig -a".
Without the "-a", it only lists devices that are "up".
andrewstillie
Fri Mar 22, 2013 11:05 am
Is there some way I can undo the install of tightvncserver?
Could this install have have corrupted the WiFi dongle driver?
andrewstillie
Mon Mar 25, 2013 8:11 pm
Here is a snapshot of ifconfig with the -a.
I notice there is still no IP address....any clues?
Joe Schmoe
Mon Mar 25, 2013 8:21 pm
Well, you asked why it didn't show up in "ifconfig" and the answer is "because it wasn't 'UP'".
When you do "ifconfig -a", it is there.
Note, incidentally, that in the old days, "UP" and "has an IP address" were synonymous. Nowadays, however, I've noticed that it shows as "UP" even when it doesn't have an IP address. I treat this as an anomaly.
andrewstillie
Mon Mar 25, 2013 8:25 pm
OK...what else can I try?
andrewstillie
Mon Mar 25, 2013 8:30 pm
Lol...I need to re-title this post.....Can anyone help me fix WiFi connection on wlan0?
andrewstillie
Tue Mar 26, 2013 4:08 pm
Is there anyway I can check if I have a wifi connection to router?
ie not a IP Address allocation issue.
mahjongg
Tue Mar 26, 2013 4:10 pm
andrewstillie wrote:Lol...I need to re-title this post.....Can anyone help me fix WiFi connection on wlan0?
Because you ask nicely... ;)
andrewstillie
Re: Can anyone help me fix WiFi connection on wlan0
Tue Mar 26, 2013 4:47 pm
My apologies not missing my manners....Please and thank you added to all previous posts. ;)
jaylongley
Tue Mar 26, 2013 8:27 pm
if your wireless is setup properly and your vnc is too, did you set your tightvncserver to start on boot?
http://www.InstantSupportSite.com/self-help/
