realtek
Keep python script running?
Thu Mar 21, 2013 3:04 pm
When executing my python script it seems to pause or something when I close down Putty and stops running properly.
How can I execute this so it continues to run?
realtek
Re: Keep python script running?
Thu Mar 21, 2013 3:08 pm
hmm, it looks like it actually quits rather than runs! and leaves the GPIO pins on which I set to HIGH.
sej7278
Thu Mar 21, 2013 3:45 pm
make it run as a daemon from an init script, plenty of posts about it on here.
here's my init script for a gpio python program, you'll need to make some small modifications above the "test -x" line, then put it in /etc/init.d/ and run "sudo update-rc.d pi-radio defaults" or whatever you call the file
### BEGIN INIT INFO
# Provides:          pi-radio
# Required-Start:    autofs $all
# Required-Stop:     $remote_fs
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Starts and stops the Raspberry Radio
# Description:       Starts and stops the Raspberry Radio
### END INIT INFO
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
DAEMON=/usr/local/bin/pi-radio
NAME=pi-radio
DESC="Raspberry Radio"
test -x $DAEMON || exit 0
. /lib/lsb/init-functions
set -e
case "$1" in
  start)
    echo -n "Starting $DESC: "
    start-stop-daemon --start --quiet --pidfile /var/run/$NAME.pid --background --make-pidfile --exec $DAEMON
    echo "$NAME."
  stop)
    echo -n "Stopping $DESC: "
    start-stop-daemon --stop --oknodo --quiet --pidfile /var/run/$NAME.pid
    echo "$NAME."
  restart)
    $0 stop
    sleep 1
    $0 start
    echo "Usage: $0 {start|stop|restart}" >&2
    exit 1
esac
exit 0
realtek
Thu Mar 21, 2013 3:54 pm
thanks, ah yes thanks :)
realtek
Thu Mar 21, 2013 4:15 pm
hmm, I have the below script but it doesn't seem to run the python script.
If I try stopping the service it cannot kill the process because it doesn't exist... I tried creating another script that does "sudo python temper.py" but it still does the same result?
    ### BEGIN INIT INFO
    # Provides:          piTemp
    ### END INIT INFO
    DAEMON=/home/pi/Projects/temper.py
    NAME=piTemp
    DESC="Raspberry Temperature"
    set -e
    case "$1" in
      start)
        echo "$NAME."
      stop)
        echo "$NAME."
      restart)
        $0 stop
        sleep 1
        $0 start
        exit 1
    esac
    exit 0
sej7278
Thu Mar 21, 2013 8:56 pm
i think Provides, NAME and DAEMON all have to be the same and the same as the python filename (remove the .py extension) and init script
also don't put the python file in your $HOME directory, put it somewhere in the $PATH e.g. /usr/local/bin
and have you got the shebang in the python file - i.e. #!/usr/bin/python as the first line, and does it have 755 permissions?
also don't use sudo, this is an init script that runs as root anyway!
realtek
Fri Mar 22, 2013 10:30 am
OK, All sorted!
Yes I forgot the shebang at the beginning! and I also placed it in /usr/local/bin, makes a bit more sense!
Thank you
Leestons
Sat Mar 23, 2013 1:18 pm
I just use screen
sudo apt-get install screen
then you SSH into your pi, type screen and bobs your uncle. Then when you close the SSH session and wish to come back, SSH into your pi, type screen -r and you will be back where you left off.
sej7278
Sat Mar 23, 2013 5:27 pm
Leestons wrote:I just use screen
not really a workable solution, an init script is the way to go, saves you having to login first too.
alexeames
Sat Mar 23, 2013 7:21 pm
sej7278 wrote:not really a workable solution, an init script is the way to go, saves you having to login first too.
Yes it is. I use this method all the time with my weather station Pi, on which I have two python programs running on different ttys, one for the ADC and one for the LCD
Alex Eames RasPi.TV, RasP.iO
sej7278
Sat Mar 23, 2013 8:11 pm
well ok its not the "proper" way to do it then, same as nohup, its a hack.
alexeames
Sat Mar 23, 2013 9:02 pm
Depends what you want. If I want to log in and see what the latest readout is, I think it's the best way of doing the job. If that's a hack, then OK.
cookn
Fri May 17, 2013 10:47 pm
ok solved my autofs problem now on startup i hav:
File "/etc/init.d/rfidsql", Line 12
SyntaError: invalid syntax
[FAIL] startpar: service(s) returned failure: rfidsql ... failed!
protoShiro
Tue Jun 11, 2013 4:06 am
cookn wrote:ok solved my autofs problem now on startup i hav:
this should be run as a bash script, not python
ghp
Sat Jun 15, 2013 8:44 am
simple solution is to start the program with an '&' at the end of the command line. This creates a daemon process, running detached from the session.
In unix, processes are started as childs of the console session, and closing the session means stopping the processes. Detached processes are not affected.
Example rfe.py:
import time
import os
while True:
    print("hello again")
    os.system("logger hello again")
    time.sleep(3)
will print a message to the console, but also to /var/log/messages.
Start in a console session by 'python rfe.py &' and in another session monitor the logger output 'tail -f /var/log/messages'.
Then after a while close the first console session, and the program continues to run: you will see ongoing messages.
To stop this daemon, us 'ps -A | grep python', and you get the process id of this process. Then 'sudo kill <processid>' will stop this. Be careful, mistyping the processid will kill nothing or maybe something useful.
Of course, the program will not be restarted after a shutdown. This is what the init.d-thing is about.
Gerhard
Maddo
Tue Jun 25, 2013 6:38 am
cronjob..
00 09-18 * * 1-5 /home/pi/somescript.py &
Return to “Python”
