woodpecker
RTL8188-hostapd auto start and iptables restore
Thu Mar 21, 2013 2:38 pm
Hi all,
I am using the Edimax EW7811Un in AP mode using hostapd, I installed the RTL8188 specific hostapd from git and then followed the instructions here - http://elinux.org/RPI-Wireless-Hotspot
Everything will start fine from the command line and it works a treat but I am struggling to make it start from boot, when I enter:-
sudo update-rc.d hostapd enable
I get this error
update-rc.d: using dependency based boot sequencing
update-rc.d: error: no runlevel symlinks to modify, aborting!
Also the iptables-restore is not working, in etc/network/interfaces I have:-
up iptables-restore < /etc/iptables.ipv4.nat
But I have to keep re-entering the iptables rules, they are not restoring.
Any advice appreciated
Andy
raspinoob
Re: RTL8188-hostapd auto start and iptables restore
Sat Mar 23, 2013 4:39 pm
I had the same hostapd update.rc issue. Apparently the symbolic link to the /etc/init.d/hostapd script is missing in the /etc/rcx.d directories.
I fixed it with this:
sudo ln -s /etc/init.d/hostapd /etc/rc2.d/S02hostapd
When I issue the command "sudo update-rc.d hostapd enable" it still complains that the runlevel 2 overrides the defaults. But the service starts after reboot, so I can live with that.
Maybe this helps...
heing
Sat Nov 28, 2015 7:24 pm
Try this:
sudo update-rc.d hostapd defaults
williamdgmartin
Fri Mar 04, 2016 8:22 pm
Can someone help me please? How do i install the RTL8188 specific hostapd from git ? Im a newbie, thanks.
therealman
Thu Jul 28, 2016 8:50 pm
heing wrote:Try this:
Thanks, that worked great.
williamdgmartin wrote:Can someone help me please? How do i install the RTL8188 specific hostapd from git ? Im a newbie, thanks.
Hi. Hope this reply isn't too late! Follow the instructions on the blog of the creator of the specific hostapd: https://jenssegers.com/43/realtek-rtl81 ... spberry-pi
Happy to help if you need more help and good luck :)
If you told people in the 1970s that in around 40 years time, a computer the size of a credit card would have 1GB of RAM, they'd have laughed at you.
