mikerr
HOWTO setup adblock (for midori and all browsers)
Sat Mar 16, 2013 2:41 pm
Here's how to setup adblocking on your Raspberry Pi
Chromium and Iceweasel support adblock plus, but I find them way too memory/cpu intensive on the Pi to be usable,
and midori has an adblock option which isn't supported in our version on the Pi.
But there is a solution !
You can block all the ads in any browser on the Pi by using a hosts file from the guys at http://winhelp2002.mvps.org
– they maintain an up-to-date host file with a list of ads which we can use.
Open a terminal window and type (or copy and paste) the following:
wget http://winhelp2002.mvps.org/hosts.txt
sudo mv hosts.txt /etc/hosts
Ads are now gone !
You can stop there and ads are blocked – but you will quickly realise that many sites show an error where the advert used to be.
In step 2 below I'll install a tiny webserver to blank out the ad error pages:
mikerr
Re: HOWTO setup adblock (for midori and all browsers)
Sun Jul 07, 2013 1:35 pm
Those error ad pages can be removed by running a local webserver that shows a blank image in their place.
Here's how:
Kwakd – simple webserver to serve blank webpages / images
http://code.google.com/p/kwakd/
We’ll have to download and compile it on the raspberry pi:
wget http://kwakd.googlecode.com/files/kwakd-0.3.tgz
tar -xvf kwakd-0.3.tgz
cd kwakd-0.3
./configure
make
now we can run it:
sudo ./kwakd -p 80 &
Ads are now removed, and blank images are served in their place.
Enjoy!
http://www.redrobe.com/mike/setting-up- ... pberry-pi/
Smoking_SD
Fri Mar 21, 2014 10:52 am
For PC's I use junkbuster / privoxy not tried on raspberry pi yet....
