Hello all,
I'm working on a raspberry-based project, and am new to this whole thing. I'm the type who prefers finding the information myself, as opposed to asking, but I've come across too many 'be careful with power, or you'll burn your pie' so I would like to confirm a couple of things. Apologies if these have been asked and answered before.
I'm interested in using the Pi to power a group of LEDs (among pother things, but those don't need the pins). If I understand correctly, I'll be able to run a wire from the 3.3v Pin1 to the LEDs to power them. What I would like to confirm is:
- from what I've read, the pin outputs at 50mA. Is this done by default, or does this need to be set?
- If the above needs to be set, how would I tell the Pi to power it on at launch?
- Am I correct in my understanding that the wiring needs to go 3.3v pin > LED > resistor (if applicable) > ground pin?
- Would using the 5v pin be a better choice in this case?
- Is there any forseeable problem in connecting the LEDs in a parallel array?
Thank you for your time.
