Ced
Wifi and Lan
Tue Mar 12, 2013 10:38 am
hello I would like to connect my raspberry with an ethernet relay board with RJ45 port and simultaneously be connected to the Internet with a WiFi USB dongle. For WiFi everything works but the ethernet port does not recognize the card over.
FTrevorGowen
Re: Wifi and Lan
Wed Mar 13, 2013 1:44 pm
More detailed info. needed ...
What is "an ethernet relay board with RJ45 port"? (I can think of at least two interpretations of that phrase - probably both "wrong" :) ) IE. Make, model no. ...
Does the ethernet port on the Pi work O.K. when connected to a LAN port on your router (if you have one) or to another computer (laptop, netbook)? NB: WiFi not in use at the same time.
Trev.
Ced
Re: Wifi and Lan
Sat Mar 30, 2013 12:44 am
Hi, my ethernet relay board it that :http://denkovi.com/productv/74/snmp-8-r ... m35dz.html
My ethernet por it's O.K, but i don' t know how to do for WiFi and ethernet work together.
