Dr1zzle
USB Hard Drive Issue.
Mon Mar 11, 2013 4:55 pm
I have plugged in a USB hard drive so that I can use my Pi as a torrent slave, but the problem is, when the Pi turns the monitor off due to no interaction, the HDD will unmount, and when I come back to it later, obviously all the torrents have stopped.
Also, I have to mount and set a mount directory every time I power up the Pi which is not convenient. I'm sure there must be a way around this, but I have not been able to find the answer on here so far.
I am using Raspbian.
Any help would be very much appreciated.
RaTTuS
Contact: Twitter YouTube
Re: USB Hard Drive Issue.
Mon Mar 11, 2013 5:03 pm
how have you got it all setup?
editing /etc/kbd/config and changing BLANK_TIME=30 will stop the screen switching off after a reboot
adding a line in
/etc/fstab
you will get an auto mount setup.
Covfefe
FTrevorGowen
Mon Mar 11, 2013 10:09 pm
Dr1zzle wrote: Also, I have to mount and set a mount directory every time I power up the Pi which is not convenient. I'm sure there must be a way around this, but I have not been able to find the answer on here so far.
More info. on auto-mounting and editing /etc/fstab can be found in the wiki eg. http://elinux.org/RPi_Adding_USB_Drives
Trev.
