leexgx
when i touch the network/USB chip keyboard mouse stop
Fri Mar 08, 2013 1:24 am
when i touch (very lightly) the network/USB chip the keyboard mouse stop working partly
i can press ctrl alt del it does an normal restart
was going to fit some tall heatsinks to them (power, CPU and USB/network chip)
pluggy
Re: when i touch the network/USB chip keyboard mouse stop
Fri Mar 08, 2013 7:35 am
Sounds like an RMA job. Sounds like its another one that got short changed in the Reflow oven. It definitely shouldn't do that....
I must not tread on too many sacred cows......
leexgx
Fri Mar 08, 2013 6:58 pm
i probably buy another one or go back to the shop and see if another one does it as well, as i have not done any thing yet to set the over-voltage bit yet (not needed to )
i may have this today https://www.modmypi.com/5v-2A-modmypi-r ... wer-supply as my pi is bit unstable with some of the USB charges i have (this one runs at 5.25v so it should get the target voltage of 5v when cable is plugged in)
leexgx
Sun Mar 10, 2013 2:45 am
leexgx wrote:i probably buy another one or go back to the shop and see if another one does it as well, as i have not done any thing yet to set the over-voltage bit yet (not needed to )
well the power pack i got from them does really work well, or should i say maybe to well as the test points on the PI was showing 5.25v-5.19v i was expecting the power loss in the cable to drop the voltage down to 5v i guess the PSU is kicking more then 5.25v out (i guess the 2m one i have got see what results i get from that)
obcd
Sun Mar 10, 2013 7:50 am
Make sure your meter has a fresh battery. Most of them tend to measure a higher voltage when the meter battery voltage starts to lower. Besides that, a Pi voltage not exceeding 5.25V should be fine.
