rurwin
Which crimp tool?
Thu Mar 07, 2013 11:58 am
I know there are people around with electronic R&D/Production experience. Perhaps I can pick your brains.
I want a crimp tool to attach the terminals that connect to the GPIO pins. Not the 26-way IDC, the individual pin sockets: for example http://uk.rs-online.com/web/p/pcb-conne ... s/7194294/
Generally I solder them and then mash them around with a pair of pliars until they fit the housing, but I've got a project coming up that means I ought to at least try to do it right.
The recommended hand tool for crimping them costs £500. The not recommended tool costs £150. Maybe I can get away with the Molex-KK-capable tool, which must be similar, for "only" £30.
Would that work? Is there a better or even cheaper option?
joan
Re: Which crimp tool?
Thu Mar 07, 2013 12:05 pm
As an amateur.
I have one of these http://www.hobbytronics.co.uk/test-equi ... tool-sn28b
Works well enough for the volumes I do.
paulie
Thu Mar 07, 2013 12:55 pm
joan wrote:As an amateur.
I have something similar (with 16/10/6 dies) which works well on Anderson Powerpoles.
There are others with smaller dies.
All at around the £30 mark- probably less with research.
It has been my custom to use Xeyes
rurwin
Thu Mar 07, 2013 1:39 pm
THANK YOU!
Not only the tool, but also the pins and housings for a reasonable price.
Return to “Off topic discussion”
