HKwhyIP
Solder an additional USB port to model A?
Thu Mar 07, 2013 2:57 am
Hi all,
I want to add one more USB port to Model A without using an external USB hub. My idea is to solder an additional USB port to the Model A board as indicated by the red arrow in the attached picture.
Will my idea work? Is any software change required?
Ken
Re: Solder an additional USB port to model A?
Thu Mar 07, 2013 4:51 am
Sorry, no. It won't work. :(
Those pins aren't connected to anything on the board and the CPU only has one USB interface.
On the model B the CPU USB connects to the network chip, which also has a USB hub in it and provides connections for the twin USB socket. On the model A this chip is missing and the single socket is wired directly to the CPU instead.
repton
Fri Mar 08, 2013 10:31 pm
No it won't work, the main difference between the B and the A is that the USB hub IC is missing off the model A so those pins aren't connected to anything. If you want two USB ports get a model B.
Paul
UK Supplier of 1-Wire components, kits and modules:
http://www.sheepwalkelectronics.co.uk/
HKwhyIP
Sat Mar 09, 2013 4:06 am
Thanks for all the quick responses!
