WanaGo
PWM Audio Output Capability
Wed Mar 06, 2013 11:36 pm
Hello All
Potentially a stupid question, but the PWM Audio output on the Pi which goes to the 3.5mm Jack - what is this capable of driving, other than into an amplifier.
Is it capable of driving a small 8ohm (0.5W nominal) 18mm speaker directly (or 2 speakers I should say)?
Doesn't have to drive it 'awesomely', but if it can safely be connected that is the info I am wanting to know.
redhawk
Re: PWM Audio Output Capability
Wed Mar 06, 2013 11:45 pm
The Pi on-board can barely drive a pair of headphones so passive speakers will not work at all (and yes I have tried it).
You'll need an amplifier circuit based on the TDA2822M or 2 x LM386 to get anything out of your speakers.
The other alternative is to use a USB audio dongle which won't be loud either but nevertheless much more audible.
Richard S.
WanaGo
Thu Mar 07, 2013 12:41 am
Thank you
Just the info I was after
Much apprecaited
