Wheel_nut wrote:Boot time is very dependent on the speed rating and performance of the DS Card you are using. A Class 10 Card is MUCH faster than a Class 4 Card.
The class of an SD card is about sustained write speed in video applications :
https://www.sdcard.org/developers/overview/speed_class/
How long a Pi takes to boot is all about read speed, it is not defined by the class. They all read much faster than they write, in many cases a lower class will read faster than a higher class card.
My Sandisk class 4's will boot the latest Raspdian in 24 seconds. Using the perfomance tests on elinux :
http://elinux.org/RPi_SD_cards#SD_card_performance
It writes at 5.3 MB/S and reads at 21.5 MB/S which puts it up with the best of those tested on read speed. A class 4 should have a minimum sustained write speed of 4 MB/S. How fast it reads isn't defined.
