I am a first time Raspberry Pi user (however I have quite a bit of experience in linux (Ubuntu, Mint etc.)) I installed OpenELEC 2.99.3 on an SD card (from my Ubuntu Machine to use in the Pi)
The system booted up fine, however there is no network connection (Wired Connection)
In the network information section I have the following:
Link: Connected
MAC Address: left this out for convenience
IP Address: 169.254.188.164
Subnet Mask: 255.255.0.0
Gateway: [blank]
Primary DNS: 127.0.0.1
Secondary DNS: [blank]
Internet: Not connected. Check Network Settings
My router (Netgear N300/DGN2200) does not show the device in the list of attached devices.
My router operates on 192.168.0.XXX for DCHP, and is set to assign addresses automatically.
The cable works as it is connected to a microserver in the same room at the moment, which works fine.
Seems to be a DHCP error. I have googled the error and found a number of pages, which generally have one or two posts, but no solutions:
No connection to the internet (169.254.x.x)
http://www.raspberrypi.org/phpBB3/viewt ... 4&p=271760
Big Problems with RPi with Open Elec install
http://forum.xbmc.org/showthread.php?tid=148463
DCHP Failure on Raspberry Pi
http://openelec.tv/forum/69-network/606 ... spberry-pi
Please can someone try and help me reach a solution to this.
Would love to see a [Solved] somewhere in this thread
