Narf03
How to disable power saving ?
Mon Feb 25, 2013 9:42 am
In command prompt mode, if i never type anything within lets say 15 mins, the monitor will go power saving mode(blank), need to know are there any "not so difficult" method to turn that feature off or configure it a huge number ? (instead of 15 mins, 15 years should be enough)
Thanks.
PeterO
Re: How to disable power saving ?
Mon Feb 25, 2013 9:56 am
Assuming that by " command prompt mode" you mean in console mode rather than in X windows, then look at the setterm man page.
PeterO
redhawk
Mon Feb 25, 2013 10:04 am
You need to edit the following file /etc/kbd/config
then change BLANK_TIME= to BLANK_TIME=0
and POWERDOWN_TIME= to POWERDOWN_TIME=0 then reboot..
Your Pi should not blank the screen while idling. :)
Richard S.
Narf03
Mon Feb 25, 2013 10:12 am
Ya, console mode, sorry, im a windows guy, and thanks redhawk, ill try that.
RaTTuS
Contact: Twitter YouTube
Mon Feb 25, 2013 10:20 am
redhawk wrote:You need to edit the following file /etc/kbd/config
Richard S.
^whs
if you want to do it on a machine without rebooting
setterm -blank 0
Covfefe
Cloudcentric
Mon Feb 25, 2013 11:58 am
Richard S.
^whs
setterm -blank 0
Thanks that seems easy, will give it a try !
digitalhippie
Mon Feb 25, 2013 3:41 pm
Put this in your /etc/rc.local before the "exit 0":
/usr/bin/setterm -blank 0 -powerdown off
and execute the same command as root (sudo /usr/bin/setterm -blank 0 -powerdown off) once. No reboot required.
Another useful trick which works on any shell:
sudo /bin/chvt 1 # change console to tty1
sudo /bin/chvt 7 # change to graphical console (X11)
Nfarrow
Contact: Website Facebook Twitter YouTube
Mon Oct 01, 2018 5:48 am
I get this error when I run it as root. Any idea why?
root@PiServer:~# /usr/bin/setterm -blank 0 -powerdown off
setterm: argument error: 'off'
Twitter: @farrownick
Instagram veggievampire
I own a lot of Pis....
DirkS
Mon Oct 01, 2018 6:07 am
According to the docs valid values are 0-60 with 0 = off.
So use '0' instead of 'off'
RaTTuS
Mon Oct 01, 2018 8:07 am
this will not do what you expect in Stretch ,
as systemd terminals are slightly different
the easiest way to remove the console blanking is to add
consoleblank=0
to the end of /boot/cmdline.txt
and reboot
Covfefe
Return to “Advanced users”
