sharksfan98
Setting up i2c for C?
Sun Feb 24, 2013 10:13 pm
I'm setting up i2c for an Application written in C, but I've not been able to find any how-to's for it. I'm running a model-b Raspberry Pi on Debian 6 with LXDE. Can anybody show me how to set up i2c so I can use it in a C Application?
Thanks for any help in advance
j35570
Re: Setting up i2c for C?
Tue Feb 26, 2013 7:21 am
I have successfully connected an lcd and some buttons on the i2c bus.
First you need to install the i2c drivers: http://www.skpang.co.uk/blog/archives/575
Then you need to include the i2c header:
#include <linux/i2c-dev.h>
Take a look at my project at http://raspify.stockenstrand.com or download a test project at https://github.com/j3557o/RPi_i2c_test/
Good luck!
/j3557o
gordon@drogon.net
Tue Feb 26, 2013 9:28 am
It's all fairly straighforwards in C - but the operation can be a bit confusing and you have no direct control over the I2C bus phases (or appear not to, however)...
But if you want some slightly easier to use access, then I write some wrappers for the standard I2C calls and made it part of wiringPi.
And example program to talk to an MCP23017 GPIO expander is:
http://unicorn.drogon.net/q2w.c
The rest can be found:
https://projects.drogon.net/raspberry-p ... c-library/
-Gordon
