The raspberry pi is placed in the middle and any data traveling between each device is captured by it. A second USB to Ethernet adapter is used to provide the second interface. The adapter i used is a USB to Fast Ethernet 10100 Mbps Network LAN Adapter Vista Linux 27723.
When the Raspberry pi starts it loads two scripts. The first is this shell script below:
ifconfig eth0 0.0.0.0
ifconfig eth1 0.0.0.0
brctl addbr bridge0
brctl addif bridge0 eth0
brctl addif bridge0 eth1
ifconfig bridge0 upThe second script that starts after the one above is this python script.
import subprocess
#from dbupload import upload_file #Used for Dropbox uploading
from datetime import datetime # Used the genreate the filename
count = 0 #Counts the number of files that have been dumped
while True:
count = count + 1
fileName = str(datetime.now().day) + "-" + str(datetime.now().month) + "-" + str(datetime.now().year) + " AT " + str(datetime.now().hour) + "-" + str(datetime.now().minute)
tcpDumpProcess = subprocess.Popen(["tcpdump", "-Z", "root", "-w", fileName, "-i", "bridge0", "-G", "60", "-W", "1"]) #Sets up the TCPDump command
tcpDumpProcess.communicate() #Runs the TCPDump command
print "Currently dumping file number " + str(count) + "."
#upload_file(fileName,"/",fileName, "YOUR_EMAIL","YOUR_PASSWORD") #Uploads the dump file to dropbox
#print "File uploaded Successfully"With both these files saves onto the raspberry pi and executed from the rc.local file at startup it will allow the raspberry pi to automatically capture network traffic between two devices.
