bryanb
audio out, and headless
Wed Feb 13, 2013 4:00 am
Im setting up a Raspberry pi for a little practical joke.
I need it to play audio out of the analog audio jack, but I've found that it only plays when the analog video is also connected to a video output device (my TV in my testing).
Can this be made to run the audio without there being any video device around? Using 2013-02-09-wheezy-raspbian as the OS on it.
thanks.
socialdefect
Re: audio out, and headless
Wed Feb 13, 2013 8:00 am
It should work... For the output check if the right output is selected by alsa by running:
alsamixer
Press [F6] to select the correct interface.
For playing headless audio I like to use Mplayer or VLC (package might be named cvlc) as they both have their advantages. Both are more than appropriate to be used in scripts etc.. I use cvlc for example to play video's that are activated by placing a photo with RFID chip in front of a computer.
Have Fun!!
== If it's not broke... I'm not done fixing it! ==
bryanb
Thu Feb 14, 2013 3:52 am
Thanks! I think that will work out just fine.
