raspberrypiguy1
TUTORIAL: How to get a button working with the Pi!
Sat Feb 09, 2013 12:56 pm
Dear forumers!
This is just a quick patch of code for one of my older tutorials! Feel free to watch it all here:
http://www.youtube.com/watch?feature=en ... GdtAA&NR=1
And here is the code I use in the program!
import RPi.GPIO as gpio
gpio.setmode(gpio.BCM)
gpio.setup(17, gpio.IN)
while True:
    input_value = gpio.input(17)
    if input_value == False:
        print('The button has been pressed...')
        while input_value == False:
Be careful you copy the correct indentation, otherwise Python will throw up some nasty errors!
The Raspberry Pi Guy
Last edited by raspberrypiguy1 on Sun Sep 15, 2013 9:41 am, edited 1 time in total.
Matt, The Raspberry Pi Guy YouTube channel, author of Learn Robotics with Raspberry Pi, available now: http://mybook.to/raspirobots, Computer Science & Electronics Undergraduate at The University of Edinburgh
rew
Re: TUTORIAL: How to get a button working with the Pi!
Sun Feb 10, 2013 9:42 am
On my system where I trigger a snapshot, I configure the pin with a pullup. This saves having to mount the pullup externally.
(I happen to use a different pin).
GPIO.setup(4, GPIO.IN, pull_up_down=GPIO.PUD_UP)
Oh. And in my script I have a "time.sleep (0.1)" in both cases where the switch is stable. Otherwise the CPU will be polling as fast as it can all the time, wasting power and crowding out other programs that might need to do something.
Check out our raspberry pi addons: https://www.bitwizard.nl/shop/
tonyhughes
Sun Feb 10, 2013 9:52 am
Here's mine...
import RPi.GPIO as GPIO
import time
import os
GPIO.setmode(GPIO.BCM)
GPIO.setup(17, GPIO.IN)
prev_input = 0
while True:
  input = GPIO.input(17)
  if ((not prev_input) and input):
    os.system("sudo shutdown -h now")
  prev_input = input
  time.sleep(0.05)
Uses basically no appreciable CPU, and catches the button press regardless of length, and only catches it once.
raspberrypiguy1
Sun Feb 10, 2013 10:28 am
Ahhh! Great! Looks good! Might even update my tutorial! Maybe!
tonyhughes
Sun Feb 10, 2013 8:38 pm
Don't credit me for it though. It's cobbled from code lifted here, there, and everywhere.
:oops:
metachris
Sun Feb 10, 2013 9:22 pm
tonyhughes wrote:Here's mine...
import time
import os
prev_input = 0
while True:
  prev_input = input
  time.sleep(0.05)
I've taken the liberty to simplify your code while preserving the functionality:
import time
import os
while True:
    if GPIO.input(17):
    prev_input = input
    time.sleep(0.05)
pythonhosted.org/RPIO
metachris
Mon Feb 11, 2013 6:28 pm
import time
import os
while True:
    if GPIO.input(17):
    prev_input = input
    time.sleep(0.05)
After reading over it again I saw I missed the 'prev_input=...' line. Also I'd advise to add the pulldown resistor at GPIO.setup:
import time
import os
GPIO.setup(17, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
while True:
    if GPIO.input(17):
    time.sleep(0.05)
You could also do the same with interrupts like this (using my GPIO2 module):
import GPIO2
def do_shutdown(*args):
GPIO2.add_interrupt_callback(17, do_shutdown, edge='rising')
GPIO2.wait_for_interrupts()
RussoNC
Mon Feb 11, 2013 9:36 pm
Thank you !! This is EXACTLY that I was looking for, i'm new in this the raspberry pi's GPIO so it's a little confusing, so thank you so much for your tutorials, continue like this! :D
Whant to see MySQL, nginx in action on the Raspberry pi ? Check my site: www.pirepository.com
Rosenkrantz
Fri Jan 29, 2016 11:25 am
Hello does any of you guys know how to use a button and an led. When the button is pressed the led will light until you press the button again?
Hope for help
gordon77
Fri Jan 29, 2016 12:09 pm
#!/usr/bin/python
import time
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD)
GPIO.setup(18, GPIO.OUT) # led, pin 18 to gnd (with approx 300 ohm resistor)
GPIO.output(18,GPIO.LOW)
GPIO.setup(12, GPIO.IN, pull_up_down=GPIO.PUD_UP) # Button, pin 12 to gnd (with approx 300 ohm resistor)
led = 0
while True:
   if GPIO.input(12) == False and led == 0:
      GPIO.output(18, GPIO.HIGH)
      led = 1
      time.sleep(.5) # debounce
   elif GPIO.input(12) == False and led == 1:
      GPIO.output(18, GPIO.LOW)
      led = 0
paulv
Fri Jan 29, 2016 12:29 pm
You may not realize this, but several of the solutions presented here actually rely on switch or button bounce and glitches.
The ultimate test for your routine would be to use a potmeter (10..50K) between the 3V3 and ground, and feed the wiper with a 10K resistor (to avoid loading) to the GPIO input. Something like this :
Hysteresis Measurement.png (9.16 KiB) Viewed 30149 times
If you are surprised and want to know why, have a look here :viewtopic.php?uid=52264&f=28&t=134394&start=0
Success!
gordon77
Fri Jan 29, 2016 1:21 pm
It works for me whatever it relies on. :D
I know there are problems with edge detection, so I don't use that.
Gordon
gurudattakr123
Fri Mar 17, 2017 5:03 pm
I am using 3 buttons for three different functions. For example, when i press 1st button it must display 1st button, for 2nd it must display 2nd etc. Help me with this. I am new to python.
from gpiozero import Button
button1=17
button2=27
button3=22
GPIO.setup(button1,GPIO.IN,pull_up_down=GPIO.PUD_UP)
GPIO.setup(button2,GPIO.IN,pull_up_down=GPIO.PUD_UP)
GPIO.setup(button3,GPIO.IN,pull_up_down=GPIO.PUD_UP)
print('press a button')
while(1):
      if GPIO.input(17)==0:
           print('button1 pressed')
      elif GPIO.input(27)==0:
           print('button2 pressed')
      else :
           print('button3 pressed')
Thank you
Frankie Yip
Sun Jun 11, 2017 10:54 am
gurudattakr123 wrote:I am using 3 buttons for three different functions. For example, when i press 1st button it must display 1st button, for 2nd it must display 2nd etc. Help me with this. I am new to python.
button1=17
button2=27
button3=22
while(1):
      else :
Thank you
Hi gurudattakr123
May I know is your above code workable. Cause I have download and unable to run the code.
