sbaratheon
rpi-update fail
Wed Feb 06, 2013 6:06 pm
I get this when I try to update:
2013-02-06 18:03:46 (4.50 MB/s) - `/usr/local/bin/rpi-update.tmp' saved [6043/6043]
 *** Relaunching after update
 *** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS
 *** ARM/GPU split is now defined in /boot/config.txt using the gpu_mem option!
 *** We're running for the first time
 *** Setting up firmware (this may take a few minutes)
fatal: destination path '//root/.rpi-firmware' already exists and is not an empty directory.
 !!! Failed to download new firmware files
Any ideas?
DirkS
Re: rpi-update fail
Wed Feb 06, 2013 6:18 pm
Probably a left-over from an earlier, failed attempt. Remove directory '//root/.rpi-firmware' and run rpi-update again.
Gr.
Dirk.
