pl259
./bootstrap = ./cmake
Mon Feb 04, 2013 7:36 pm
I am trying to install the folowing program:
https://www.cgran.org/wiki/AIS
and in the install intructions it refers to ./bootstrap, but i can not find any file named bootstrap. Is this refering to the mkdir build, cd build, cmake ../, process?
thanks
PeterO
Re: ./bootstrap = ./cmake
Mon Feb 04, 2013 7:42 pm
./bootstrap is a file called "bootstrap" located in the current directory "."
That form is normally used to run an executable file that is located in the current directory. Note that "." should not be put in the PATH.
PeterO
pl259
Mon Feb 04, 2013 7:48 pm
when i look at the downloadable files:
https://github.com/bistromath/gr-ais
There is no file anywhere in there named bootstrap. There are cmake files. Is bootstrapping an older technique than cmake, and the install instructions were just not updated? thanks
technion
Mon Feb 04, 2013 9:57 pm
If you grab an old version...
https://github.com/bistromath/gr-ais/tr ... 9f91e869a2
The bootstrap file is there. It would appear that they have changed their build process, and not updated their documentation, as you had thought.
The commit that overhauled the build states "cmake is the future", however, I wouldn't call autoconfig/make an obsolete system (just about every current project uses it).
I would suggest you will need to do some Google on the 'cmake' product, it would appear likely that you'll need to install cmake itself as a first step.
pl259
Tue Feb 05, 2013 1:12 pm
thanks for the advice. I already have used cmake a couple of times but had some trouble with this program and wiped my sd card clean and just wanted to make sure now that i have restarted that i am doing this step right. Thanks so much for the help.
