posi90
RXTX - CommPortIdentifier
Sun Feb 03, 2013 12:19 pm
I want java to connect to serial port. Minicom and GTKTerm already work, but i cant make java to connect.
CommPortIdentifier portIdentifier = CommPortIdentifier.getPortIdentifier(portName);
throws
gnu.io.NoSuchPortException
        at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:269)
        at main.connect(main.java:17)
        at main.main(main.java:131)
CommPortIdentifier.getPortIdentifiers();
does not list any ports.
I cant explain why GTKTerm and Minicom work and java does not.
This is the tutorial i followed:http://eclipsesource.com/blogs/2012/10/ ... -and-rxtx/
Can anyone help me please?
KG
Poseidon
posi90
Re: RXTX - CommPortIdentifier
Sun Feb 03, 2013 12:21 pm
I'm sorry for double post!
crackers
Sun Feb 03, 2013 7:29 pm
I stopped using RXTX on a Linux system a while back. I've really appreciated their efforts and used the heck out of it for years, but it got too hard to get that .so file loaded in the various environments I was trying out.
I recommend setting up ser2net on the Pi and using java.net.Socket to talk to it. Works like a charm.
posi90
Sun Feb 03, 2013 7:50 pm
Got it working now:
I just linked the port to another file like in this Post: http://pblog.ebaker.me.uk/2011/09/proce ... yacm0.html
sudo ln -s /dev/ttyAMA0 /dev/ttyS80
Thank you very much =)
Pizerg
Mon Feb 04, 2013 11:58 am
Just add this line on the top of your code:
System.setProperty("gnu.io.rxtx.SerialPorts", PORT_NAME);
kdekooter
Wed Feb 06, 2013 1:29 pm
It is definitely a permissions issue.
On my pi the permissions for the port are:
crw-rw---T  1 root dialout 188,   0 Feb  6 11:53 ttyUSB0
I changed the permissions:
sudo chmod 666 /dev/ttyUSB0
And now my java program runs fine.
-rst-
Wed Feb 06, 2013 2:36 pm
kdekooter wrote:It is definitely a permissions issue.
Maybe better to add the user (you plan to run the app as) to the dialup group?
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
neoro89
Fri Feb 08, 2013 7:10 pm
posi90 wrote:Got it working now:
Hi posi90,
I'm also running into difficulties with this issue. However when I try your suggestion I get the following:
RXTX Warning: Removing stale lock file. /var/lock/LCK..ttyS80
Did you have similar issues or did it work fine first attempt?
Thanks.
billllyboy
Fri Jan 17, 2014 2:42 pm
works but when I reboot the link disappear
It is possible to make it permanent?
Fri Jan 17, 2014 10:54 pm
billllyboy wrote:Hello,
You'll need to write a udev rule /etc/udev/rules.d
I'll let you Google for the syntax.
This is a doctor free zone.
jackdmarquez
Thu Jun 05, 2014 8:59 pm
Hi posi90,
Thanks.
Did u fix that issue?? i'm getting the same.
jackdmarquez
Thu Jun 05, 2014 9:02 pm
Hi i am getting this issue
Does anyone has fixed it??
Thanks.
Return to “Java”
