Stephenlorio
I need HDMI to component video converter.
Fri Feb 01, 2013 3:13 am
I see 2 options:
1) HDMI male to Component male. Not powered. Not with chip or IC. $$5.00 USD
http://www.ebay.com/itm/1-5m-5ft-HDMI-t ... 484e3974a4
2) HDMI male to Component male box. Powered. With chips and ICs inside. $80.00 USD
http://www.ebay.com/itm/Digital-to-Anal ... 35c3999e94
which do i need? Could you link me to a better price and quality?
Thank you!
--Steve
zardoz66
Re: I need HDMI to component video converter.
Fri Feb 01, 2013 6:24 am
the cable (unpowered) is a very short run (only 1.5M), the powered one should give you a better signal on a longer run.
Zardoz
Raspberry Pi 3 | Raspbian Jessie | 32GB Samsung EVO+ | D-Link 7 port USB HUB | Sabrent CRW-EXT 6-Slot Card Reader | 64GB USB Storage. Other RPi's - 2x RPi1b, 1x Rpi1b+ 1x Rpi2b, 2x Rpi3b
Join us on IRC #raspberrypi at https://webchat.freenode.net/
Fri Feb 01, 2013 7:15 am
The first link is to a cable that is only suitable for HDMI with Analog/Component output already built in. The Pi only has Digital output, so no good.
The second is to a Digital to Analog converter. That will work, but is rather expensive.
I wonder if a HDMI(Digital) to VGA converter linked to a VGA to Component converter might work and be cheaper?
