noah98
when i move my sd card in the raspberry pi the os screws up
Thu Jan 31, 2013 9:44 pm
when i move my SD card in the raspberry pi the OS screws up.
I will move my SD card in the SD slot of the raspberry pi and it barely barely barely 8 more barelys moves. it doesn't even move a centimeter. When it moves barely the whole pi and the OS screws up is this normal and to be expected?
Jim JKla
Re: when i move my sd card in the raspberry pi the os screws
Thu Jan 31, 2013 10:08 pm
The obvious answer is don't move it,
You probably have a dry joint somewhere I have mine encased in lego but it's been moved lots. ;)
riffraff
Mon Feb 04, 2013 9:50 am
This is a joke, right:
Patient: "Doc, it only hurts when I do this!"
Doctor: "Then don't do that."
Jim JKla
Mon Feb 04, 2013 10:26 am
I hope you meant a millimeter noah as the slot is only about a centemeter deep.
all the other checks still apply ;)
Burngate
Mon Feb 04, 2013 12:29 pm
1) Is the SD card holder broken?
2) Are any of the card holder's soldered connections damaged?
3)Look at the springs that connect to the card - are any slightly lower than they should be?
3a)How about the leaf spring that detects the card?
4) is the card itself dirty or damaged?
Return to “Off topic discussion”
