Agustina
Create a program in Java wherein if a year is a leap year will return true otherwise false
Wed Jun 16, 2021 11:38 am
This is my code
public class Leapyear{
  public static void main(String []args){
    for(int year =2000; year <=2020; year++){
      if((year % 400 == 0) || ((year % 4 == 0) && (year % 100 != 0)))
        System.out.println("Year " + year + " is a leap year");
      else
        System.out.println("Year " + year + " is not a leap year");
but the question is: I don't know that how to return true if it's a leap year and false if it's not a leap year.
[spamlink removed]
echmain
Re: Create a program in Java wherein if a year is a leap year will return true otherwise false
Wed Jun 16, 2021 11:55 am
Smells like a homework assignment and has nothing to do with Raspberry Pi.
W. H. Heydt
Wed Jun 16, 2021 5:59 pm
This is my code
      else
I see that you are restricting your range to 2000 to 2020. What do you plan to do if the request year falls before the conversion to the Gregorian calendar (varies anywhere from 1582 to 1923, depending on country)?
bls
Wed Jun 16, 2021 6:39 pm
A bit from 1983 on the Gregorian calendar and whether 2000 should be a leap year: https://www-users.cs.york.ac.uk/susan/joke/decly.htm
Pi tools:
Quickly and easily build customized-just-for-you SSDs/SD Cards: https://github.com/gitbls/sdm
Easily run and manage your network's DHCP/DNS servers on a Pi: https://github.com/gitbls/ndm
Easy and secure strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
Wed Jun 16, 2021 7:12 pm
https://stackoverflow.com/a/11595914/3491475
if ((year & 3) == 0 && ((year % 25) != 0 || (year & 15) == 0))
    /* leap year */
Languages using left-hand whitespace for syntax are ridiculous
DMs sent on Twitter/LinkedIn will be answered next month.
The use of crystal balls and mind reading is prohibited.
fanoush
Wed Jun 16, 2021 7:31 pm
but the question is: I don't know that how to return true if it's <something> and false if it's not <something>.
Looks like the question is not about leap year at all. It is about returning a (boolean) value.
Now you just print different text messages instead of returning some value.
To return value you should move the leap year logic into separate function with return value and then in main method just use the return value to print different messages.
Wed Jun 16, 2021 11:25 pm
Or the question could be about returning an exit code from the program, not just returning a boolean from one function to another within the program.
To return an exit code use "System.exit(code);"
Where "code" is a "0" or "1" to indicate a leap year or not.
jojopi
Thu Jun 17, 2021 12:28 pm
Are we actively trying to be unhelpful? (Especially Heydt.)
There should be a specification for how a particular year is requested, what range is expected, and how the result is to be returned. There is no point in us guessing what all that might be. We can all design a program, but OP will only get the marks if their program works to the specification they have.
There is no point returning (or exiting) inside a fixed for loop, so OP is missing something important in terms of how the year(s) will be passed, and needs to re-read the specification.
GlowInTheDark
Thu Jun 17, 2021 12:34 pm
You gotta admit: This (the above quoted text) is classic!
It's like:
Person 1: For the purposes of this discussion, we are considering only grey elephants.
Person 2: But what about green elephants???? Whacha gonna do then?
Person 1: Reading comprehension, much?
Poster of inconvenient truths.
Linux zealot and proud of it.
Thu Jun 17, 2021 8:13 pm
No.
GlowInTheDark wrote: It's like:
No.
The question as posted is not clear.
Is it about returning a true of false from some function?
Or is it about returning an exit code from the entire program that indicates leap year or not?
Or why is the expected input of such a limited range of years, according to the example code given?
Or, is this homework exercise even about leap years at all? Maybe it's about one of the above, or something else.
This needs clarification from the OP before a sensible solution can be suggested.
scruss
Thu Jun 17, 2021 10:20 pm
import java.time.LocalDate;
public class isleap {
    public static boolean isLeapYear(int year) {
	return (LocalDate.of(year, 3, 1).getDayOfYear() > 60);
    public static void main(String[] args) {
        System.out.println("2021:");
	System.out.println(isLeapYear(2021));
        System.out.println("2020:");
	System.out.println(isLeapYear(2020));
gives:
false
2020:
true
I'm assuming that LocalDate isn't sufficiently smart to return Hijri dates or similar based on locale setting. That would be cool, but irritating for learners.
I've never written any Java. I hope never to do so again. But never, ever hand-roll date functions, because you don't know the edge cases.
Since Java's put me in a late-90s frame of mind, I'd just like to say that the time is @972 .beats.
Pronouns: he/him
GlowInTheDark
Fri Jun 18, 2021 6:29 am
If you've never done something, how can you be worried about doing it again?
mahjongg
Sun Jun 20, 2021 12:14 pm
you are missing this was a post from a post edit spambot.
Spamlink deleted and spammer banned.
kept thread intact though..
akashmishra
Sun Sep 12, 2021 2:07 pm
package javaapplication;
public class JavaApplication {
int year;
public JavaApplication(int year) {
this.year = year;
public boolean isLeapYear() {
if (this.year % 4 == 0) {
// check if year divided by 100 for century test
if (this.year % 100 == 0) {
if (this.year % 400 == 0) {
return true;
} else {
return false;
else {
return true;
} else {
return false;
public static void main(String args[]) {
JavaApplication obj = new JavaApplication(2021);
if (obj.isLeapYear()) {
System.out.println("Leap Year");
} else {
System.out.println("Not Leap Year");
Try above program for leap year.
You may refer multiple java program and key concepts in java such as https://www.quizcure.com/java/what-is-a ... va-program for Copy constructor, Hashmap, Method overriding and more.
Return to “Java”
