petercli
how to strip REALLY thin wires?
Sun Jun 13, 2021 8:20 pm
hi
how do I strip leads on this chip led : https://evandesigns.com/products/chip-n ... 8378885168 ?
my wire stripper (goes 20 to 30 awg ,) but seems to big for this wire. I also tried a razor blade.
Is the coating painted on?
Thanks, Peter
Imperf3kt
Contact: Twitter
Re: how to strip REALLY thin wires?
Sun Jun 13, 2021 8:34 pm
The covering looks like plastic to me.
Not the greatest, but sometimes burning the end works when you can't physically strip the wire.
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
ghp
Sun Jun 13, 2021 8:38 pm
katesimon123
Mon Jun 14, 2021 4:27 am
Yeah, you need to use tweezers or small scalpels, if you're new to soldering. Check out these necessary embedded tools: https://www.theengineerin gprojects.com/2016/11/necessary-embedded-tools.html
Gavinmc42
Mon Jun 14, 2021 5:00 am
Try heating the plastics, even a soldering iron might work.
The plastic tends to shrink and expand away from the end, that might be enough to solder to the LED.
It looks like PVC, won't work if Teflon.
I'm dancing on Rainbows.
gordon77
Mon Jun 14, 2021 6:09 am
Something like this: https://www.weidinger.eu/en/p/wl22775
Wow, not cheap !!
LTolledo
Mon Jun 14, 2021 10:19 am
the wire looks like the ones used on those cheapo headphones or speaker set bought from the dollar store,
enamel (or polyurethane) coated stranded wires....
dipping the ends to be stripped in soldering flux, I use a soldering iron (at proper soldering temp) with a bit of solder on the tip...
its strip and tin at the same time...
added...
poking around my LED inventory I happen to find my still unused "chip LED with wire"....
which seemed similar to the OP..
the package indicates
Wire: 250mm ⌀0.16mm (its a single core, polyurethane coated wire, in red and copper color, and tinned at the other ends)
Some people be like:
pidd
Mon Jun 14, 2021 4:26 pm
If its a polyurethane enamel then it is solder-through, no need to strip. This is the same as Verowire/Vero-pens.
Imperf3kt
Contact: Twitter
Mon Jun 14, 2021 8:38 pm
No, they don't really. If you view with a smart phone, you can zoom in easily closer an see quite easily that the coating is some form of plastic.
55:55:44:44:4C
52:4C:52:42:41
Milliways
Tue Jun 15, 2021 1:39 am
Years ago I used to wire-wrap my prototypes.
This uses 30AWG (0.01") with a tough teflon coating.
I had a dedicated stripper, but often used a cheap tool (which was basically crossed blades with a V notch and an adjustable depth stop) because it was faster.
gordon77
Tue Jun 15, 2021 5:15 am
Like these ?
https://www.screwfix.com/p/magnusson-wi ... lsrc=aw.ds
Milliways
Tue Jun 15, 2021 6:12 am
Like these ?
No.
I have some like these and they are good for multi-strand wire. I wouldn't dream of using these for wire wrap wire.
The strippers I used were much simpler - just 2 strips of hardened steel like scissors with a cam to adjust spacing.
