I have spent the last week reading through the forums on the RPi. For many years I have worked with visual studio -- C#. I have also used Visual Studio C# for playing with my Netduino board.
I am very interested in the RPi as well.
I am trying to discover how I can use my existing C# knowledge and work with the the RPi
Questions:
a) Does a SD card come with the RPi to get it up and running?
b) If so, what will come on the SD disk that comes with the RPi -- a version of Linux? If so, what version of Linux?
c) What will I need to download, compile, install to get Mono working on RPi?
d) If I get Mono working, am I correct in thinking that writing code in Visual Studio C#, and then save it on to the SD card...I can use Mono to (compile? and) run the code?
e) Do I need Mono if I want to use other Visual Studio programs such as IronPhyton or IronRuby?
f) Finally -- if I didn't use Visual Studio C#, IronPython or IronRuby....what appears to be the most popular program that others will be using to start programming on the RPi?
Thanks, John
