HermannSW
Pollard Rho loop analysis
Fri May 21, 2021 5:35 pm
In thread "gmp (Gnu multiple precision arithmetic lib) 5x faster on intel i7 than on Pi400 (two samples)"
viewtopic.php?f=33&t=311893
factorization algorithm based on Pollard Rho method with arbitrary precision arithmetic was presented.
In this thread I want to look into the loops that are built by function "x->(x^2+a) mod n", starting with n prime, and later n=p*q product of primes.
I said "to look", by that I mean using graphviz for vizualisation (sudo apt install graphviz).
This is basic small C-program for creating graphviz dot file:
$ cat loop.c
#include <stdio.h>
#include <stdlib.h>
int main(int argc, char *argv[])
  unsigned n=atoi(argv[1]);
  unsigned a=atoi(argv[2]);
  unsigned x;
  printf("digraph D {\n");
  printf("size=8 8\n");
  for(x=0; x<n; ++x)
    printf("%u->%u\n", x, (x*x+a)%n);
  printf("}\n");
It is used by bash script "mak" fot creating digraph for parameters n and a, and display the result:
$ cat mak
#!/bin/bash
./loop $1 $2 > $1_$2.dot
neato -Tsvgz $1_$2.dot > $1_$2.svgz
eog $1_$2.svgz
For the kind of digraphs created, force-based "neato" is the best layout algorithm, and not the standard "dot" or any other of the graphviz layout program alternatives.
Taking prime 83 as example, this is n=83 a=0, showing big diameter cycles:
n=83 and a=1 leads to very small diameter circles, but some very long paths to the circles:
Finally n=83 and a=15 leads to mixture of long diameter circles and long paths:
https://stamm-wilbrandt.de/2wheel_balancing_robot
ejolson
Re: Pollard Rho loop analysis
Fri May 21, 2021 5:42 pm
The graph is supposed to look like
ρ
right? I think I see that happening.
HermannSW
Fri May 21, 2021 5:55 pm
ρ
Yes, you are right:
https://en.wikipedia.org/wiki/Pollard%27s_rho_algorithm
I looked into bigger "n"s, and that was the reason I did choose ".svgz" format for the generated graphs:
SVG (scalable vector graphics) is scalable, and .svgz uses compression as well to keep size low.
This is graph for biggest prime n=9973 below 10000. As you can see there are many circles:
Zooming in to up to 2000% with gnome image viewer "eog" shows the fine details, parts from two big circles nearly touching each other:
I wrote a small program to analyze the circles (it allocates two arrays of size 4*n, so n cannot be too large):
https://gist.github.com/Hermann-SW/83de ... 641c26c590
$ ./analyze 5 0
1 1
0: 1 0 1
1: 2 0 1
2: 2 2 3
3: 2 2 3
4: 2 1 2
c 2
m 2 1.0
l 1 1.0
lm 3 2.0
lm2 3
The first line says that two circles of length 1 are found (self-loops from number to itself, here 0->0 and 1->1 for "x->(x^2+0) mod 5".
The rows below tell for each number in range 0..n-1 (before the colon) values l, m and l+m.
"c 2" mean two circles found.
Then for l (length of circle), m (length of path until number on cycle reached) and lm (lm[x]=l[x]+m[x]) are reported.
First number is overall maximum, 2nd number is average over all numbers 0..n-1.
Finally lm2 reports lm[2] for start number "2" which is default start value for Pollard Rho method (which has default "a=1").
Using the analysis for n=9973 and a=0 we get more information about the image shown:
$ ./analyze 9973 0 | grep -v :
1 1 92 92 92 92 92 92 276 276 92 276 276 92 276 276 92 2 6
c 19
m 2 1.2
l 276 213.9
lm 278 215.1
lm2 94
There are 19 circles in total, 6 of which have length 276 and 9 of which have length 92.
HermannSW
Fri May 21, 2021 6:18 pm
Now lets look at N=997 and a=0:
As can be seen there are three big circles, and analysis says they are of length 82:
$ ./analyze 997 0 | grep -v :
1 1 82 82 82 2
c 6
m 2 1.2
l 82 81.0
lm 84 82.2
lm2 84
Now doing prime factorization for n-1=996 = 2^2 * 3 * 83, biggest prime factor 83 is just 1 bigger than longest circles found in analysis. This phenomenon was true for nearly all "n"s I tried with a=0.
For finding biggest circles, I looked at primes p, where (p-1)/2 is also prime (safe primes):
https://oeis.org/A005385
This is graph for safe prime n=107 (a=0):
Analysis shows a single big circle of length 52, and 107=2*53+1:
$ ./analyze 107 0 | grep -v :
1 1 52
c 3
m 1 0.5
l 52 50.6
lm 53 51.1
lm2 53
So likely "a=0" is not a good choice for Pollard Rho factorization algorithm.
HermannSW
Fri May 21, 2021 6:38 pm
Now looking at RHO-100 1st RSA factoring challenge number:
https://en.wikipedia.org/wiki/RSA_numbers#RSA-100
The factors p and q are no safe primes, but both [p-1 and q-1] have a very long biggest prime factor (18/26 digits):
$ ./factorize 37975227936943673922808872755445627854565536638198
37975227936943673922808872755445627854565536638198: 2 3167 3613 587546788471 3263521422991 865417043661324529
$ ./factorize 40094690950920881030683735292761468389214899724060
40094690950920881030683735292761468389214899724060: 2 2 5 41 2119363 602799725049211 38273186726790856290328531
$ bc -q
n=1522605027922533360535618378132637429718068114961380688657908494580122963258952897654000350692006139
p=37975227936943673922808872755445627854565536638199
q=40094690950920881030683735292761468389214899724061
n-p*q
0
HermannSW
Sun May 23, 2021 8:30 pm
All Pollard Rho algorithms I have seen sofar use "x->(x^2+a) mod n" with different, but fixed values for a.
We have seen that a=0 is likely not a good choice.
Some "a"s are good for some inputs, but not that good for other inputs.
I found a method to use a mixture of a1, a2, ..., ak, use:
(x->(x^2+a1) mod n) + n
then
(x->(x^2+a2) mod n) + 2*n
then
finally
x->(x^2+ak) mod n
and then repeat with a1, a2, ...
For multiplication, difference building and gcd() computation, the multiple of n offsets don't care.
I need to rewrite analysis.c tool to report numbers for using a1, a2, ..., ak ...
HermannSW
Thu Jun 10, 2021 10:15 pm
In other thread posting simple hare and tortoise Pollard Rho algorithm was started in parallel on 9 cores with different values for "a":
viewtopic.php?f=33&t=311893&p=1876289#p1876289
Instead of having to wait for 37 seconds to get 31digit number factored with default value "a=1", first program stopped with factorization after only 8 seconds:
Question now is how to choose set of 24 "a" values (I have access to a machine with 24 physical cores) so that first factorization gets reported fast. It needs to be considered that algorithm gets recursively called with "a+1" in case "gcd(hare-tortoise,n)==n":
https://gist.github.com/Hermann-SW/bfa0 ... rize-c-L73
Because of that choosing successive numbers for "a" as in above example is likely not good ...
HermannSW
Thu Jun 10, 2021 11:02 pm
Next experiment, factoring (2^61-1)^2 that took 1534 seconds on i7.
I started 24 programs in background, with values "1 and primes <89" for a.
First program finished in 178 seconds only!
Default a=1 took 1631 seconds.
Last finisher was a=53 in 2240 seconds:
# for i in 1 2 3 5 7 11 13 17 19 23 29 31 37 41 43 47 53 59 61 67 71 73 79 83; do ./factorize 5316911983139663487003542222693990401 $i & done
# 5316911983139663487003542222693990401(37): 2305843009213693951 2305843009213693951
[239379195] 178081430292ns
5316911983139663487003542222693990401(61): 2305843009213693951 2305843009213693951
[381929703] 296462510871ns
5316911983139663487003542222693990401(79): 2305843009213693951 2305843009213693951
[564229691] 463837995445ns
5316911983139663487003542222693990401(2): 2305843009213693951 2305843009213693951
[916265383] 727448510261ns
5316911983139663487003542222693990401(29): 2305843009213693951 2305843009213693951
[966671113] 730703246286ns
5316911983139663487003542222693990401(11): 2305843009213693951 2305843009213693951
[1060573965] 791627178335ns
5316911983139663487003542222693990401(73): 2305843009213693951 2305843009213693951
[1158177900] 861668098355ns
5316911983139663487003542222693990401(71): 2305843009213693951 2305843009213693951
[1195387796] 929350141287ns
5316911983139663487003542222693990401(83): 2305843009213693951 2305843009213693951
[1246192557] 929880773927ns
5316911983139663487003542222693990401(23): 2305843009213693951 2305843009213693951
[1335540845] 1009334758484ns
5316911983139663487003542222693990401(17): 2305843009213693951 2305843009213693951
[1432697673] 1073120510105ns
5316911983139663487003542222693990401(59): 2305843009213693951 2305843009213693951
[1448906908] 1096388994755ns
5316911983139663487003542222693990401(13): 2305843009213693951 2305843009213693951
[1801257367] 1346426834616ns
5316911983139663487003542222693990401(7): 2305843009213693951 2305843009213693951
[1809569828] 1347825243786ns
5316911983139663487003542222693990401(31): 2305843009213693951 2305843009213693951
[1861347840] 1390923977909ns
5316911983139663487003542222693990401(47): 2305843009213693951 2305843009213693951
[1880798495] 1400540741266ns
5316911983139663487003542222693990401(67): 2305843009213693951 2305843009213693951
[1900420809] 1415451734862ns
5316911983139663487003542222693990401(41): 2305843009213693951 2305843009213693951
[2003126736] 1493349090289ns
5316911983139663487003542222693990401(43): 2305843009213693951 2305843009213693951
[2133065076] 1589138138134ns
5316911983139663487003542222693990401(1): 2305843009213693951 2305843009213693951
[2163790305] 1631049634692ns
5316911983139663487003542222693990401(19): 2305843009213693951 2305843009213693951
[2212260579] 1648327735182ns
5316911983139663487003542222693990401(5): 2305843009213693951 2305843009213693951
[2511875037] 1945819858899ns
5316911983139663487003542222693990401(3): 2305843009213693951 2305843009213693951
[2932193235] 2190418722150ns
5316911983139663487003542222693990401(53): 2305843009213693951 2305843009213693951
[3010950498] 2240799600863ns
HermannSW
Fri Jun 11, 2021 6:06 am
I tried to factor 54 decimal digit square of Mersenne prime M89=(2^89-1).
There are 46 primes below 200, and I chose 1 and 65537 as values for "a" in addition (see very right of long lines).
I had to kill all processes now, after more than 6 CPU hours runtime on each, with none of the 48 programs having reported factorization:
# ps -wl | grep "factorize [0-9]*6321" | head -3
R     0 116151 111188  6888   624 pts7  23:06 06:20:57 ./factorize 383123885216472214589586755549637256619304505646776321 1
R     0 116152 111188  6888   632 pts7  23:06 06:21:54 ./factorize 383123885216472214589586755549637256619304505646776321 2
R     0 116153 111188  6888   624 pts7  23:06 06:20:36 ./factorize 383123885216472214589586755549637256619304505646776321 3
# ps -wl | grep "factorize [0-9]*6321" | tail -3
R     0 116196 111188  6888   684 pts7  23:06 06:21:54 ./factorize 383123885216472214589586755549637256619304505646776321 197
R     0 116197 111188  6888   680 pts7  23:06 06:41:54 ./factorize 383123885216472214589586755549637256619304505646776321 199
R     0 116198 111188  6888   684 pts7  23:06 06:19:31 ./factorize 383123885216472214589586755549637256619304505646776321 65537
So better algorithm and/or better "set of 48 'a's" is needed to factor M89^2 ...
HermannSW
Fri Jun 11, 2021 11:55 am
I did add original brent cycle finding algorithm as option to factorize.c:
https://gist.github.com/Hermann-SW/bfa0 ... /revisions
Now simple help is printed when run without arguments:
# ./factorize
factorize [n [a] [floyd|brent]]
  Determines 1st factor for composite n with timing;
  hangs indefinitely for prime n.
"brent" option is typically more than double as fast than floyd.
I did repeat the 24 parallel programs run to factor (2 ^61-1)^2.
First solution was reported after 68 seconds for brent, compared to 178 seconds for floyd.
The order of completion for the different "a" values is identical for first three entries only (68/114/180 vs. 178/296/463 seconds):
# for i in 1 2 3 5 7 11 13 17 19 23 29 31 37 41 43 47 53 59 61 67 71 73 79 83; do ./factorize 5316911983139663487003542222693990401 $i brent & done
[239379200] 68965957453ns (brent)
[381929728] 114078558342ns (brent)
[564229696] 180483982185ns (brent)
[597693920] 189778132962ns (brent)
[707049312] 203749813136ns (brent)
[916265408] 248934910426ns (brent)
HermannSW
Sun Jun 13, 2021 2:56 pm
There are two reasons why "Brent cycle finding" is faster that "Floyd cycle finding" in factorize.c:
  1. for Floyd there are 3 f() computations per loop [f(x) and f(f(y))]
    https://gist.github.com/Hermann-SW/bfa0 ... rize-c-L56
    while for Brent there is one "f(x)" inside loop
    https://gist.github.com/Hermann-SW/bfa0 ... ize-c-L112
    and one matching outside the loop
    https://gist.github.com/Hermann-SW/bfa0 ... ize-c-L135
  2. the costly "gcd()" is computed for each loop for Floyd, but only every (when k becomes >=32) 32nd loop for Brent
    https://gist.github.com/Hermann-SW/bfa0 ... ize-c-L120
So ratio 3/2 for f() computation and 32/1 for gcd() computation per loop for Floyd compared to Brent, resulting in Brent being more than 2x faster than Floyd.
While Brent is faster than Floyd for Pollard Rho, it is no magic.
I did start 40 "Brent" factorize programs Friday night (on CPUs with 24 cores/48 threads), with values for "a" of 1..20, 101..110 and 1001..1010.
None of them has completed yet after 40 hours of runtime each, to factor 54 decimal digit number (2^89-1)^2 ...
$ bc -q
(2^89-1)^2
P.S:
For a prime p: 2^(p-1) mod p = 1
For product of two primes n=p*q: 2^((p-1)*(q-1)) mod n = 1
"bc -q" output:
print n, "=", p, "*", q, "\n"
1081=23*47
(2^(p-1))%p
1
(2^(q-1))%q
1
(2^(n-1))%n
165
(2^((p-1)*(q-1)))%n
1
HermannSW
Tue Jun 15, 2021 11:11 pm
I wanted to know more about the cycle lengths of "f(x)=(x^2+a) mod n", for simplicity with a=0. Instead of composite numbers n=p*q being product of two primes, for analysis looking at primes n. This is diagram for "f(x)=(x^2+0) mod 31":
30: 2 3 5 | 1 1 4 4 2 4
I used original "factorize.c" from gmplib to factor "p-1" for prime "p", and then used "analyze.c" shown earlier in this thread to determine the cycle lengths:
$ for p in 3 5 7 11 13 17 19 23 29 31 37 41 43 47 53 59 61 67 71 73 79 83 89 97;\
> do for t in `./factorize.orig $(($p-1))`; do echo -n "$t "; done;\
> echo -n " | "; ./analyze $p 0 | grep -v : | head -1; done
2: 2 | 1 1
4: 2 2 | 1 1
6: 2 3 | 1 1 2
10: 2 5 | 1 1 4
12: 2 2 3 | 1 1 2
16: 2 2 2 2 | 1 1
18: 2 3 3 | 1 1 6 2
22: 2 11 | 1 1 10
28: 2 2 7 | 1 1 3 3
36: 2 2 3 3 | 1 1 6 2
40: 2 2 2 5 | 1 1 4
42: 2 3 7 | 1 1 3 6 2 3 6
46: 2 23 | 1 1 11 11
52: 2 2 13 | 1 1 12
58: 2 29 | 1 1 28
60: 2 2 3 5 | 1 1 4 4 4 2
66: 2 3 11 | 1 1 10 10 10 2
70: 2 5 7 | 1 1 12 4 12 3 3
72: 2 2 2 3 3 | 1 1 6 2
78: 2 3 13 | 1 1 12 12 12 2
82: 2 41 | 1 1 20 20
88: 2 2 2 11 | 1 1 10
96: 2 2 2 2 2 3 | 1 1 2
Most times biggest prime factor of "p-1" (minus 1) is a cycle length of "p":
52: 2 2 13  |  1 1 12
Sometimes biggest cycle length of "p" is smaller (11) than biggest prime factor of "p-1":
And sometimes it is bigger (6):
Not that easy to fully describe how the relation is ...
P.S:
Now nearly 40*100=4000 CPU hours completed since last Friday night, still Brent cycle finding Pollard Rho algorithm has not factorized 54 decimal digit number (2^89-1)^2 for any of the 40 "a" values:
(on workstation with two 2.6GHz Intel® Xeon® Gold 6126 processors with 24 cores (48 hardware threads) in total)
HermannSW
Wed Jun 16, 2021 6:59 pm
I got more insight into the number of cycles and maximal cycle lengths!
And I used the Online Encyclopedia of Integer Sequences (oeis.org) for that.
#cycles can be determined by copy+paste of the numbers reported into oeis.org input field:
$ for((i=3; i<=100; ++i)); do ./analyze $i 0 | grep -v : | head -2 | tail -1 | cut -f2 -d\ ; done
There is exactly one matching sequence A023153:
https://oeis.org/search?q=2+2+2+4+3+2+3 ... &go=Search
Maximal cycle length:
$ for((i=1; i<=88; ++i)); do ./analyze $i 0 | grep -v : | head -1 | sed "s/ /,/g" | python -c "print(max(input()))"; done
Again exactly one matching sequence A279186:
https://oeis.org/search?q=1+1+1+1+1+1+2 ... &go=Search
HermannSW
Tue Jun 22, 2021 11:02 pm
Factorization is still running, 40 processes with 263.5 CPU hours each is 10540 CPU hours in total.
I always thought that maximal cycle length in Pollard Rho is of order sqrt(n), but that is wrong in general.
I learned from sequence A248218 (period of x->(x^2+1) mod n with start value 0)
https://oeis.org/A248218
example a(357911) = 54670, that powers of 71 have long cycles.
I used analyze.c to compute a(71^i) with 2<=i<=6.
And the period length is 770*71^(i-2) for n=71^i.
770/71^2=0.15274747073993255306, so period for those composite numbers is linear.
I used analyze.c
to further determine all start values that end up on start value 0 cycle (that numbered 1).
A(n) being the number of thos start values, A(71^i) = 3711 * 71^(i-2) for i=2..5:
$ ./analyze $((71*71)) 1 | grep ": 1 " | wc --lines
3711
Now 3711/71^2=0.73616345963102559016, so majority of start values end on start value 0 cycle.
I submitted new results to oeis.org, the draft is in review currently:
https://oeis.org/draft/A248218
Computing a(71^5) with analyze.c did use 26.9g ram during computation.
For computing a(71^6) I did not have access to a computer with 26.9*71=1910GB ram, so I used new period.c
https://gist.github.com/Hermann-SW/eeb0 ... 761ab38998
that only determines period for cycle starting at some given start value.
Took less than an hour (3528 seconds) to compute a(128,100,283,921) = a(71^6) = 19,566,994,370 on Intel i7:
$ ./period $((71*71*71*71*71*71))
n=128100283921 a=1 s=0: 19566994370 [71536325699] 3528148502656ns
Let P be period computed. In case start value is on cycle already, then variable x moved P and variable z moved 2*P steps, 3*P steps in total (58.7 billion steps for previous example, those needing 1 CPU hour to compute and compare for equality (hare z and tortoise x)).
P.S
Submission was approved after review process:
  • results under Comments section
  • analyze.c and period.c in Links section
  • explanation in Prog section under "(C)"
HermannSW
Tue Jun 29, 2021 6:11 pm
I thought that linear cycle length (15%) for n=71^i with 2 <= i <= 5 is bad for runtime of Pollard-Rho factorization algorithm. The opposite is true, every value on start value 0 cycle has gcd of 71 to the value after applying "x -> (x^2 + 1) mod n" exactly 11 times, so factorization completes quickly.
HermannSW
Tue Jul 13, 2021 12:18 pm
$ cat loop.c
#include <stdio.h>
#include <stdlib.h>
  unsigned x;
  for(x=0; x<n; ++x)
  printf("}\n");
It is used by bash script "mak" for creating digraph for parameters n and a, and display the result:
$ cat mak
#!/bin/bash
eog $1_$2.svgz
I played with this again, and sometimes after changes in loop.c, I forgot to compile before calling "mak n a" and wodered why things did not change.
One option would be to add Makefile, but then 3 files are needed (Makefile, loop.c and mak).
Instead I reduced everything into single file "loop2":
https://gist.github.com/Hermann-SW/004f ... 2a37eef09f
It is combined bash script and C file.
This part is the excutable bash part:
#!/bin/bash
#if 0
if [ $0 -nt /tmp/$0 ]; then gcc -xc -Wall -Wextra <(tail -n+2 $0) -o /tmp/$0; fi
/tmp/$0 $1 $2 > $1_$2.dot
neato -Tsvg $1_$2.dot > $1_$2.svg
eog $1_$2.svg
exit
#endif
For executable name "loop2" it tests whether "/tmp/loop2" has not been compiled, or whether "loop2" timestamp is newer than that of "/tmp/loop2". If so, it extracts the C portion of "loop2" as file with "<(tail -n+2 $0)" and compiles it (as "C" with "-xc").
I changed output format from compressed SVG to just SVG, because browsers can deal with SVG.
For displaying the graph still gnome viewer is used, but opening the generated SVG in browsers allows to search for strings in the graph labels with CTRL-F.
For supporting browser search, all node labels get pre- and suffixed with non-break space Unicode U+00A0 character (that keeps labels "looking" the same). When calling "lab()" more than once in a print statement, separate buffers are needed:
char nbsp[3] = { 0xC2, 0xA0, 0x00 };
char buf[10][100];
unsigned int buc=0;
char *lab(unsigned u)
  if (++buc==10)  buc=0;
  sprintf(buf[buc], "\"%s%u%s\"", nbsp, u, nbsp);
  return buf[buc];
Now searching for label "8" in browser press CTRL+F, and then <STRG+SHIFT>a0<ENTER>8<STRG+SHIFT>a0<ENTER><ENTER>.
This part of C code created the Graphviz graph, and creates different node box shape for labels "x", when difference of "x" and "n-x" has greatest common divisor with "n" greater than 1:
  printf("size=\"8 8\"\n");
  for(x=0; x<n; ++x)
    if (gcd(dif(x, n-x), n) > 1)
      printf("%s [shape=box]\n", lab(x));
  for(x=0; x<n; ++x)
    printf("%s->%s\n", lab(x), lab((x*x+a)%n));
  printf("}\n");
Executing this command ...
pi@raspberrypi4B:~/rho $ ./loop2 91 1
... displays this graph:
If you want to play with loop2, make sure that graphviz is installed ("sudo apt install graphviz").
For using the many features of Graphviz, here is guide:
http://graphviz.org/pdf/dotguide.pdf
Now its time to investigate something new with this tool ...
HermannSW
Tue Jul 13, 2021 9:01 pm
I played with modified tools and tried non-standard polynomial transformations.
Looking at n=11*19=209 the rectangular box shapes were hard to spot when not zooming in.
So this print statement tells Graphviz to fill the box with lightgrey color:
printf("%s [shape=box,style=filled,bgcolor=lightgrey]\n", lab(x));
The first experiments went into one direction compared to the trees seen sofar in this thread:
Finally I did a completely different approach, resulting in self-loop 1->1 as the only cycle (9 o'clock of center):
Will see whether the approaches will provide advantages for factorization of n ...
HermannSW
Thu Jul 29, 2021 8:18 am
For prime p and a in 0..p-1:
a^(p-1) = 1 mod p
Today I learned that arbitrary precision binary calculator "bc" is not capable of computing above equation for really big exponents. I took smaller prime factor of RHO-100:
And got error using "bc":
$ bc -q
2^(p-1) % p
Runtime error (func=(main), adr=8): exponent too large in raise
After building gmplib
https://gmplib.org/#DOWNLOAD
building tool "pexpr" in demos ("make pexpr") allows to compute that in less than a second!
$ export p=37975227936943673922808872755445627854565536638199
$ ./pexpr "2^($p-1) % $p"
1
$ ./pexpr "2^($p-2) % $p"
18987613968471836961404436377722813927282768319100
P.S:
Playing with Rho100 prime factors:
$ a="(2*3*5*7*11*13*17*19*23*29*31*37*41*43*47*53*59*61*67*71*73*79*83*89*97)"
$ p=37975227936943673922808872755445627854565536638199
$ q=40094690950920881030683735292761468389214899724061
$ ./pexpr "$a^(($p-1)*($q-1)) % ($p*$q)"
1
HermannSW
Thu Aug 05, 2021 1:21 pm
Back from hospital I have access to the computer running the factorizations on 40 cores.
What I had not mentioned, I redirected output for "a=$i" to file "out.$i".
Today I logged into system and did an "ls -lst", and found exactly one out file with non-zero length, with a=1:
# ls -lst out.* | head -2
     4 -rw-r--r--    1 root     root           159 Jul 19 20:37 out.1
     0 -rw-r--r--    1 root     root             0 Jun 11 22:03 out.10
# date
Thu Aug  5 13:00:34 UTC 2021
That means that the other 39 "a"s are still running, each of the 39 cores having taken (19+31+4)*24+15=1335 CPU hours, or 52065(!) CPU hours in total -- without having found factor of "(2^89-1)^2".
"out.1" file with non-0 length completed on July 19, after (19+18)*24+22.5 = 910.5 CPU hours based on file timestamps.
But we know it better from the nanosecond resolution timestamp in factoring output, 910.6 CPU hours!
# echo "3278071011998301/(10^9*60^2)" | bc -ql
910.57528111063916666666
# cat out.1
383123885216472214589586755549637256619304505646776321(1): 618970019642690137449562111 618970019642690137449562111
 [3201775069376] 3278071011998301ns (brent)
The computer had 2 CPUs with 12 cores each, and 48 hardware threads, here are the details:
# cat /proc/cpuinfo | tail -26 | head -9
processor	: 47
vendor_id	: GenuineIntel
cpu family	: 6
model		: 85
model name	: Intel(R) Xeon(R) Gold 6126 CPU @ 2.60GHz
stepping	: 4
microcode	: 0x2000030
cpu MHz		: 2600.000
cache size	: 19712 KB
P.S:
So factorization for "a=1" was done in 1.25 CPU months on a single core:
$ echo "((19+18)*24+22.5)/(24*365/12)" | bc -ql
1.24726027397260273972
HermannSW
Fri Aug 06, 2021 5:52 pm
I enhanced output of factorize.c gist:
https://gist.github.com/Hermann-SW/bfa0 ... ab28057bf6
Now the two values x and z are printed.
They are on the circle of the "ρ" of Pollard Rho algorithm.
And their difference has greatest common divisor >1 with to factor number n.
This is new factoring output for square of Mersenne prime M31:
$ ./factorize `./pexpr "(2^31-1)^2"`
4611686014132420609(1): 2147483647 2147483647 (894488611079900130 2067272507081075303)
 [27081] 9542418ns (floyd)
The number 27081 reported in square brackets is the number of applications of "f(x)=(x^2+1) mod n", when started with 894488611079900130 resulting in 2067272507081075303, and when starting with 2 resulting in 894488611079900130.
This python script verifies what I stated:
def _f(_t):
    return (_t[0]**2+_t[1])%_t[2]
def _repeat(_func, _m, _t):
    for _i in range(_m):
        _t = (_func(_t), _t[1], _t[2])
    return _t[0]
def _gcd(_a, _b):
    if _a < _b:
        return _gcd(_b, _a)
    return _a if _b == 0 else _gcd(_b, _a%_b)
def _dif(_a, _b):
    return _a-_b if _a > _b else _b-_a
S = 894488611079900130
A = 1
N = (2**31-1)**2
print(_repeat(_f, 27081, (2, A, N)) == S)
T = _repeat(_f, 27081, (S, A, N))
print(_gcd(_dif(T, S), N))
Execution results in True and >1 greatest common divisor with M31^2:
$ python3 apply_funtion_n_times.py
True
2147483647
From previous posting 1.25 CPU month computation we know the iteration count as well ("[3201775069376]").
I wrote a gmplib program that does compute f^i(2) much more efficiently than Python.
This is the core:
  mpz_inits (t, t2, NULL);
  for (; i > 0; --i)
    mpz_mul (t, y, y);
    mpz_add_ui (y, t, 1);
    mpz_mod (y, y, n);
  gmp_printf ("%Zd\n", y);
I tested this code for i=10^8 and it took 13.85 seconds on another computer with Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz CPU.
I started the run 80 minutes ago, expected runtime to compute S is 32017*13.85/3600=123.2 hours, so shoud be available at 10pm next Wednesday ... (better wait 5 days than 1.25 months). Computation of T from S (for square of Mersenne prime M89) will take another 5 days after Wednesday ...
P.S:
Square of M81 has 54 digits, iteration count 3201775069376 has 13 digits, which is roughly 4th root of M81^2 [bc "l()" function is logarithm]:
$ bc -ql
l((2^89-1)^2)/l(10)
53.58333922818865274822
l(3201775069376)/l(10)
12.50539081866384008770
HermannSW
Sat Aug 07, 2021 7:12 am
The Python script I did show in previous posting is here
https://stamm-wilbrandt.de/apply_funtion_n_times.py.txt
because of this posting:
https://stackoverflow.com/questions/282 ... 9_28259967
gmplib "primes" demo allows to compute primes in a range.
Generating two different example primes bigger than 2^31 and not related to powers of 2:
$ gmp-6.2.1/demos/primes 9999999900 10000000000
9999999929
9999999943
9999999967
$ gmp-6.2.1/demos/primes 99999999900 100000000000
99999999907
99999999943
99999999947
99999999977
Running factorize to determine iteration count in square brackets as well as S and T:
$ ./factorize `./pexpr "9999999967*99999999977"`
999999996470000000759(1): 9999999967 99999999977 (105284260825628478721 31982818247523240027)
 [242536] 77006230ns (floyd)
This is same computation as in previous posting, just for new values, only the last few lines changed compared to apply_funtion_n_times.py:
$ tail -8 b.py
S = 105284260825628478721
A = 1
N = 9999999967 * 99999999977
print(_repeat(_f, 242536, (2, A, N)) == S)
T = _repeat(_f, 242536, (S, A, N))
Of course output as expected:
$ python3 b.py
True
9999999967
Without proof, but with strong evidence by 242536 examples, any value S on that cycle, with T applying _f() 242536 times on S has greatest common divisor with N ">1" (S and T move in sync one application of _f() by one):
$ tail bl.py
for i in range(242536):
    S = _f((S, A, N))
    T = _f((T, A, N))
    assert _gcd(_dif(T, S), N) > 1
print("done")
Output confirming what I stated (no assertion miss):
$ python3 bl.py
True
9999999967
done
This script finds the very first S on cycle, starting with "2":
S = 2
A = 1
C = 0
while _gcd(_dif(T, S), N) == 1:
    C = C+1
    S = _f((S, A, N))
    T = _f((T, A, N))
print(_gcd(_dif(T, S), N), C)
The determined count 216699 shows, that in this case significant path length of original 242536 function iterations was done outside of the "ρ" cycle:
$ python3 bf.py
9999999967 216699
HermannSW
Sat Aug 07, 2021 2:51 pm
More analysis on cylce C stating at 2 for n=9999999967*99999999977,
I used period.c to determine length of C:
Took nearly 17 minutes to compute length(C)=4782220904 on Intel i7:
$ time ./period `./pexpr "9999999967*99999999977"`
n=999999996470000000759 a=1 s=0: 4782220904 [157836619584084515515] 1006591834245ns
real	16m46.617s
user	16m45.582s
sys	0m0.019s
Next I computed last value f^216698(2) not on C as determined in previous posting, with new gist:
https://gist.github.com/Hermann-SW/eb4a ... b1708aac1f
$ time ./fn `./pexpr "9999999967*99999999977"` 2 `./pexpr "216698"`
315110942281694727266
 17396119ns
real	0m0.065s
user	0m0.037s
sys	0m0.038s
And the value after applying f() length(C) times to the value just computed:
$ time ./fn `./pexpr "9999999967*99999999977"` 2 `./pexpr "216698+4782220904"`
183800949111896025702
 334670086624ns
real	5m34.710s
user	5m34.294s
sys	0m0.035s
And the first value on cycle C:
$ time ./fn `./pexpr "9999999967*99999999977"` 2 `./pexpr "216699"`
906808939944183030876
 19755085ns
real	0m0.060s
user	0m0.035s
sys	0m0.034s
By definition both values computed before result in first value on C when applying f():
$ ./pexpr "(183800949111896025702^2+1)%(9999999967*99999999977)"
$ ./pexpr "(315110942281694727266^2+1)%(9999999967*99999999977)"
I created a Graphviz file showing all the facts determined for this n and cycle C sofar.
Here is Graphviz link for opening in your browser, and generated .png below:
Graphviz Fiddle link
(If you are interested in Graphviz [Fiddle], you find link to dotguide.pdf when opening above link)
If "y=(x^2+1) mod n", then "y=((-x)^2+1) mod n" as well. Since both values determined that enter first value on C are not negative of each other, their difference has a very interesting feature. Their difference has gcd() with n bigger than 1 ! So if computing "f^4782220904(x)" could be done in time polylogarithmic in 4782220904 (eg. log(4782220904)^k for some constant k), factorization would be easy and RSA not secure anymore ...
$ ./pexpr "gcd(183800949111896025702-315110942281694727266,9999999967*99999999977)"
99999999977
P.S:
length(C)=4782220904 is 47.8% of smaller prime factor 9999999967.
HermannSW
Sun Aug 08, 2021 7:36 am
I thought it would be interesting to have a cycle id in order to be able to tell whether two start values end up in same cycle or not, new gist:
https://gist.github.com/Hermann-SW/1f57 ... 40a85de254
In order to avoid the overhead of hare and tortoise running around to determine cycle, cycle_id.c assumes that start value s argument is on a cycle -- if you pass s not on a cycle the program will not halt.
do {
    ++c;
    mpz_mul (t, x, x);
    mpz_add (t, t, a);
    mpz_mod (x, t, n);
    if (mpz_cmp(z, x) > 0)
      mpz_set (z, x);
  while (mpz_cmp (x, s) != 0);
First value on cycle (173078234037530422551) needs to be determined, here for s=3:
$ ./factorize `./pexpr "9999999967*99999999977"` 1 3
999999996470000000759(1): 9999999967 99999999977 (173078234037530422551 55130608956757586602)
 [242536] 85002632ns (floyd)
With that value it takes less than 7 minutes to detemine (minimal value on cycle) cycle id (36623924692), cycle length is reported as well (4782220904):
$ time ./cycle_id `./pexpr "9999999967*99999999977"` 1 173078234037530422551
n=999999996470000000759 a=1 s=173078234037530422551: 4782220904 [36623924692] 407692850321ns
real	6m47.717s
user	6m46.518s
sys	0m0.079s
Running with first value on cycle starting with 2 from previous posting we get same cycle id (36623924692):
$ time ./cycle_id `./pexpr "9999999967*99999999977"` 1 906808939944183030876
n=999999996470000000759 a=1 s=906808939944183030876: 4782220904 [36623924692] 346275948831ns
real	5m46.304s
user	5m45.732s
sys	0m0.032s
I created digraph for n=13*43 (with "mak" tool discussed before), the cycles there are of lengths 2 and 4, so small compared to n -- maybe there are only few small cycles for n=9999999967*99999999977 as well (of length 242536 or smaller). The very long path from 2 to first value on cycle (216699) seems to indicate that huge trees exist outside of cycles for that value as well:
https://stamm-wilbrandt.de/en/forum/559_1.svg
n=9999999967*99999999977 is a 70bit number, so exhaustive search for all cycles as done with analyze.c
before in this thread will fail due to too low RAM available (biggest RAM machine I have access to has 192GB memory). 128GB with storing boolean information in bits allows for 2^40 with 128GB of memory.
$ echo "l(9999999967*99999999977)/l(2)" | bc -ql
69.76048998754189580376
HermannSW
Sun Aug 08, 2021 5:13 pm
As mentioned I already wrote about analyze.c determining all cycles and a lot of statistics information in previous postings of this thread:
My Intel laptop has 32GB of main memory, 23GB free.
Since analyze.c "unsig" type is 64bit, and two arrays of unsigs are needed, there is definitely a limit.
I did determine highest prime with 4 digits 9973:
$ gmp-6.2.1/demos/primes 9900 10000
9901
9907
9923
9929
9931
9941
9949
9967
9973
And highest prime with 5 digits 99991:
$ gmp-6.2.1/demos/primes 99900 100000
99901
99907
99923
99929
99961
99971
99989
99991
Check that both are real primes, and n=9973*99991=997210243 is a 30bit number:
$ echo $((9973*99991))
997210243
$ gmp-6.2.1/demos/factorize 997210243
997210243: 9973 99991
$ echo "l($((9973*99991)))/l(2)" | bc -ql
29.89332246087076002758
analyze.c did take 2 seconds for highest 3digit times highest 4digit prime.
And it took 20 seconds on Intel i7 for square of highest 4digit prime.
Product for highest 4digit and highest 5digit prime took 5:22min:
$ time ./analyze 997210243 1 > out.997210243.txt
real	5m22.831s
user	4m28.168s
sys	0m15.579s
s
"top" did show 14.9G resident memory for analyze running -- if really needed I could run analyze.c for bigger numbers on machine with 192GB main memory.
Wow, a lot of that time was taken by storing result on SSD, a 20.2GB file!
$ du -sm out.997210243.txt
20677	out.997210243.txt
tail of that file gives lots of statistics as discussed in previous postings of this thread -- most importantly that n has c=22 cycles:
$ tail -9 out.997210243.txt
997210242: 1 202 2302
c 22
m 451 239.4
l 2260 2173.4
lm 2711 2412.8
lm1 2302
lm2 2301
lm3 2330
lm4 2617
And "head" shows the 22 cycle lengths -- they are much smaller than square root 31579 of n=997210243:
$ head -7 out.997210243.txt
2100 2100 2260 2100 2100 2100 60 60 60 60 525 525 113 113 20 20 12 12 1 1 1 1
0: 1 203 2303
1: 1 202 2302
2: 1 201 2301
3: 2 230 2330
4: 3 357 2617
5: 1 200 2300
For "f(x)=(x^2+1) mod n" we know 0->1->2->5 -- all those end on cycle "1". The length until reaching the cycle decreases by one for each of them, from 203 for 0 to 200 for 5. Third column is sum of path length to cycle plus cycle length.
Like yesterday digraph can be computed and generated:
$ ./factorize 997210243
997210243(1): 9973 99991 (618572983 883346160)
 [220] 312979ns (floyd)
$ ./period 997210243 1 2
n=997210243 a=1 s=2: 2100 [307255815] 1157287ns
$ ./cycle_id 997210243 1 618572983
n=997210243 a=1 s=618572983: 2100 [648258] 449558ns
$ ./fn 997210243 2 $((200))
525888605
 141150ns
bf.py not needed since we know 201 for s=2 until first value on cycle already by analyze.c.
This is resulting digraph:
P.S:
grep on generated 997210252 lines "out.997210243.txt" file takes time:
$ time grep "^525888605 " out.997210243.txt
525888605: 1 1 2101
real	0m15.098s
user	0m12.473s
sys	0m2.608s
$ time wc --lines out.997210243.txt
997210252 out.997210243.txt
real	0m8.384s
user	0m5.687s
sys	0m2.684s
HermannSW
Mon Aug 09, 2021 7:17 am
Simple "grep" allows to select all numbers that end up on 1st cycle discussed in previous posting:
$ time grep ": 1 " out.997210243.txt > cycle.1.txt
real	0m32.490s
user	0m28.884s
sys	0m3.518s
89980657 numbers or 9% of all numbers end up on 1st cycle:
$ time wc --lines cycle.1.txt
89980657 cycle.1.txt
real	0m0.770s
user	0m0.531s
sys	0m0.239s
$ bc -ql
89980657/997210243
.09023238342328178432
Now I extracted all path lengths from a number to cycle 1, sorted them and printed them together with count -- we already know that 2100 numbers are on the cycle and have path length 0 to enter cycle:
$ time cut -f3 -d\  cycle.1.txt | sort -n | uniq -c
   2100 0
   6300 1
  11172 2
  18932 3
  23492 4
  28976 5
  32692 6
Wow, maximal path length to cycle 1 is 360, much more than 201 for number 2:
  36628 358
  17980 359
  17980 360
real	3m29.384s
user	3m45.972s
sys	0m1.905s
I did copy the 361 path length counts into a Libre Office calc, computed weighted sum and divided by 89980657 to determine average path length to enter cycle 1 as 198.58.
Minimal counts are 2100 numbers of path length 0 on the cycle, and 6300 numbers with path length 1 to cycle 1.
Maximal count is 915394 numbers with path length 240 to cycle 1.
Reminder, all these numbers live on directed trees finally hitting the cycle.
The indegree of a number in that digraph is in range 0..4 because f(x) is a quadratic formula "mod n".
I took the 17980 numbers with path length 360 to cycle 1 and copied them into spreadsheet.
These numbers are all examples for indegree 0, since 360 was maximal path length to cycle 1.
Then I computed f(x)=(x^2+1) mod n in column B to have all the edges from path length 360 to path length 359 numbers.
Finally I sorted the data by column B, and here we see examples for indegree 1 (858232), 2 (957952), 3 (858240) and 4 (1087616):
Finally I copied column B (numbers with path length 359 to cycle 1) into file "359".
Then I determined distribution of indegrees for those distinct 10515 numbers:
$ sort -nu 359 | wc --lines
  10515
$ sort -n 359 | uniq -c | cut -b-7 | sort -n | uniq -c
   4662       1
   4736       2
    622       3
    495       4
This is all I have to tell on statistics for numbers entering cycle 1 for now.
P.S:
Factorization alorithm determined difference of numbers on cycle with gcd() with n bigger than 1 as 220.
I did start factorization with number on cycle 1 as reported by that factorization.
As can be seen the minimal distance on cycle for gcd() with n bigger than 1 is 20!
∀s on C: gcd(s-f^20(s), n)>1
$ ./factorize 997210243 1 2
 [220] 75796ns (floyd)
$ ./factorize 997210243 1 618572983
997210243(1): 9973 99991 (212552207 25129618)
 [20] 73279ns (floyd)
$ ./fn 997210243 212552207 1
167197160
 95499ns
$ ./fn 997210243 212552207 21
353502773
 93171ns
$ ./pexpr "gcd(353502773-167197160, 9973*99991)"
9973
Return to “C/C++”
