Piminiuser
IRC client -> putty
Sat Jan 26, 2013 3:59 pm
I use my pi trough Putty, but is it possible to run a IRC programm trough putty? Not a server - but a normal client.
redhawk
Re: IRC client -> putty
Sat Jan 26, 2013 4:12 pm
There are 2 console based IRC clients that I'm aware of there maybe more but irc-ii and bitchx should suffice.
I'm not sure if there are precompiled binaries for the Pi however you can always download the sources and compile yourself.
Richard S.
Spid
Sat Jan 26, 2013 4:29 pm
EKG2
EPIC5
IIRSI
TINYIRC
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
Coburn
Mon Jan 28, 2013 8:35 am
apt-get install screen irssi
run 'screen -S IRC irssi'
....connect to irc network, etc...
CTRL+A, D to detach
Close SSH Window (or PuTTY)....
When you want to get back to your IRC client, just ssh into the Pi and do 'screen -r IRC' and there's your IRC client.
irssi is the best of the bunch. flexible, fast and really nice to play with. Make sure you read the manual though.
Mon Jan 28, 2013 10:03 am
I have been using ircii for many years now, but irssi is supposed to be better.
AutoStatic
Sat Feb 02, 2013 7:28 pm
RPi and real-time, low-latency audio: http://wiki.linuxaudio.org/wiki/raspberrypi
RPi audio repository: http://rpi.autostatic.com/
RPi and audio blog: https://autostatic.com/tag/raspberrypi/
zardoz66
Sat Feb 02, 2013 8:05 pm
+1 for irrsi
Zardoz
Raspberry Pi 3 | Raspbian Jessie | 32GB Samsung EVO+ | D-Link 7 port USB HUB | Sabrent CRW-EXT 6-Slot Card Reader | 64GB USB Storage. Other RPi's - 2x RPi1b, 1x Rpi1b+ 1x Rpi2b, 2x Rpi3b
Join us on IRC #raspberrypi at https://webchat.freenode.net/
OldRabbitdiesHard
Sat Dec 13, 2014 9:52 pm
Hi guys,
have finally managed to setup my Raspberry Pi with IRSSI and an external HDD.
Problem is, as soon as the DCC starts downloading, the current screen freezes and I have to wait until the download is finished to be able to do something again.
My setup is as follows:
Raspberry Pi B+ connected to RJ45 directly to Router.
2TB Samsung HDD to USB Hub D-LINK DUB-H4, mounted to ~/mnt/
USB Hub connected to Raspberry Pi.
Funny thing is, when I CTRL A-D the screen I can work as nothing is happening the terminal screen. I would have thought, that the entire Raspberry Pi is totally worked up.
I checked the speed on my Windows 7 Laptop - I only have a speed of about 200kB/s, while my usual average is about 2.7MB/s.
Anyone else having this issue? And what can I do about it?
Thanks for your help already.
Cheers
OrdH
OldRabbitdiesHard
Tue Dec 16, 2014 5:24 am
Hi there,
nobody knows anything about this issue? I thought there are actually a lot of people out there using IRSSI with Raspberry Pi in connection with an external HDD, do they all have the same issue or just me?
Still thankful for help.
DirkS
Tue Dec 16, 2014 11:05 am
OldRabbitdiesHard wrote:I thought there are actually a lot of people out there using IRSSI with Raspberry Pi in connection with an external HDD
I seriously doubt that...
The fact that you posted in a topic that has deceased a long time ago doesn't help either.
It's also unrelated to the original question, which was about using a console based IRC client using Putty / SSH.
AFAICS your problem is about HDD write speed... or is it download speed?
Don't really understand what you're saying here.
So the speed on Win is 200KBit?
Assuming the problem is HDD write speed: what file system is on the HD? NTFS is notoriously slow.
Gr.
Dirk.
OldRabbitdiesHard
Tue Dec 16, 2014 7:24 pm
thanks for the reply anyway. You want me to open up a new thread before we continue?
