princec
RPi3 / VC4 KMS driver / 7" display = blank
Mon May 17, 2021 10:43 pm
I've got a buildroot system here running on a Pi3 with the official 7" display attached.
When I use dtoverlay=vc4-fkms-v3d in config.txt, everything's good - logs show up, my OpenGLES app runs, but there's this terrible vsyncing problem causing it to flicker badly almost as if it's single-buffered.
So I hear the fix is to use the more recently maintained kms driver: dtoverlay=vc4-kms-v3d
However... no display ever comes up - it's black. It's running ok otherwise, just no output at all.
Perhaps there are some other parameters I need to set?
aBUGSworstnightmare
Re: RPi3 / VC4 KMS driver / 7" display = blank
Tue May 18, 2021 5:05 am
Have you added the required overlays to config.txt for using the 7in under KMS?
6by9
Tue May 18, 2021 6:11 am
dtoverlay=vc4-kms-dsi-7inch
would be the line needed.
Linux doesn't have a nice way of autodetecting DSI displays as there are a million and one potentials that could be connected. The firmware knows about 1 display, so can try it out and see if it works.
I'm still fighting this driver to get it to be reliable though.
cleverca22
Tue May 18, 2021 7:04 am
would it be possible for the firmware to auto-detect that panel, and the fact that your using the real kms driver, then auto-load the dsi overlay too?
princec
Tue May 18, 2021 10:27 am
Tried
but no joy - there's no /dev/dri directory created and so there's no card0 etc.
So I'm assuming that I also need
... so I tried adding it. I got the display back then but unfortunately attempting to actually render something caused me a crash before I could get it to init (something to do with determining available modes).
I wonder though if I'm on the right track, and need to now also specify some video mode related parameters in config.txt too?
Yours cluelessly,
Cas :)
