Apsaires
Analogue OUT Pins
Wed May 12, 2021 12:06 pm
Hi there,
I'm new to programming, so be patient with me please.... ;)
I've bought a Raspberry Pi PICO to build a project in which I realized that I need 3 analogue OUT pins. But the PICO has none, is there any way to overcame this issue?
Many thanks
André
hippy
Re: Analogue OUT Pins
Wed May 12, 2021 12:09 pm
PWM output with a resistor-capacitor to create a voltage is one way. A resistor-DAC using multiple GPIO output pins is another. You could add external DAC. What is suitable or best all depends on what your voltage out spec is.or
Reneg973
Wed May 12, 2021 9:20 pm
There are not many µC out there which support 3 DAC.
So it's a question of money, quality and frequency how your analogue output looks like.
Apsaires
Sun May 23, 2021 12:46 pm
Thanks,
I'm using an adafruit mcp4728 dac with my pico, I need to send 4 different values to it by i2c but I do not know how to do it.....
Any Help?
B.Goode
Sun May 23, 2021 12:54 pm
Thanks,
Any Help?
There is a previous discussion of this device on the Micropython forums - https://forum.micropython.org/viewtopic.php?f=14&t=7311
(The discussion far pre-dates the RP2040 and Pico, but the published solution might be generic and based only on the standard i2c interface.)
Or it seems Adafruit have a CircuitPython solution.
fivdi
Sun May 23, 2021 1:00 pm
For CircuitPython there's the MCP4728 library documented at https://circuitpython.readthedocs.io/pr ... en/latest/
The corresponding GitHub repository is at https://github.com/adafruit/Adafruit_Ci ... on_MCP4728.
Return to “General”
