alanbork
easy test for whether kms or Fkms are loaded on pi4?
Fri May 07, 2021 4:37 am
I've been switching back and forth between these a lot, and I'd like a way to make sure from within my bash scripts that the scripts I'm running are under the proper kms/drm driver. I can grep config.txt but that's only correct as long as the machine's been rebooted and seems kind of like a hack. is there something under /dev or /proc that I can check?
retired neuroscientist. raspberry pi hacking and monitor input lag methods: https://alantechreview.blogspot.com/
6by9
Re: easy test for whether kms or Fkms are loaded on pi4?
Fri May 07, 2021 7:59 am
/proc/device-tree/soc/hvs@7e400000/status will be "disabled" for fkms, "okay" for kms.
You could look at the pixelvalve, hdmi, or dsi nodes, but there are a number of options there which may or may not be enabled, whereas the HVS is required in all cases.
Note this is actually whether it is configured in device tree. It is possible that the driver failed to load and it would still report "okay" in DT.
alanbork
Sat May 08, 2021 3:55 pm
awesome. in case anybody else wants to do this, the one-liners are
fgrep -q disabled /proc/device-tree/soc/hvs@7e400000/status && echo Fkms loaded
fgrep -q okay /proc/device-tree/soc/hvs@7e400000/status && echo Kms loaded
