david_1234
advertising Bluetooth and BLE at the same time from pi4?
Mon Apr 19, 2021 1:26 pm
Hello ,
on my pi I have Bluwtooth running which I can see the name I gave to the pi
what do I need to do in order to make the pi advertise BLE also ?
so on BLE scan I will see "MyPi4_BLE"
and on "regular" bluetooth scan I will see "PI4_BT"
Thanks ,
Douglas6
Re: advertising Bluetooth and BLE at the same time from pi4?
Mon Apr 19, 2021 4:09 pm
You'll need a process running on the Pi that advertises it as a BLE device.
david_1234
Tue Apr 20, 2021 6:10 am
can you explain more ?
what kind of app\code can do it ?
also
when it will run - will stiil advertise the "regular" bluetooth name? (NOT BLE)
Thanks ,
deepo
Tue Apr 20, 2021 2:06 pm
You can have your RPi broadcast BLE using these two guides:
https://pimylifeup.com/raspberry-pi-eddystone-beacon/
https://pimylifeup.com/raspberry-pi-ibeacon/
That should show up on e.g. a BLE app for your phone.
Having that out of the way then maybe you could check if regular Bluetooth broadcasts are active as well.
