1.-I can not edit this file in / boot as it is read only and I can not change the attributes of this file (chmod or chown commands do not work. The owner is root but being SU these commands do not work).
From windows I can edit the file.
2.-I tried to rotate the screen 90 degrees to see if config.txt is running with negative results
I want to test if the RCA works. Does the HDMI connection detection by Raspberry is priority over config.txt?
Some ideas? Are there only one filesystem problem?
Thanks in advance
