Terrum
Client is not authorized to connect to...
Sun Jan 20, 2013 12:55 am
After happily setting up my Pi with VNC working fully, I just installed lighttpd and its essentials, however now when trying to execute a program with sudo, such as leafpad to edit the HTML files, it says "Client is not authorized to connect to Serverleafpad: Cannot open display:", yet without sudo it works fine.
Is this due to something I've installed that's conflicting with it or because I'm on a different desktop session (using VNC) instead of the pi's session?
I'm looking at this right now: http://unix.stackexchange.com/questions ... op-as-root and due to my lack of knowledge in Linux it pretty much goes over my head.
Hope someone can help!
JDCNServices
Re: Client is not authorized to connect to...
Wed May 28, 2014 1:38 pm
Well, I don't have an answer as much as a workaround. I actually came here with the same issue. :) Funny that it seems to be Leafpad causing the problem, as it is (so far) the only one complaining.
Anyhow, if you go to the Menu, go to Accessories | Root Terminal, it will open up a terminal as root, which will run Leafpad.
lphun074
Sat Oct 03, 2015 3:38 am
I know it has been a while and no one seemed to have an answer for this issue. After some quick searches on google, I found this website that describes a similar problem:
http://thepiandi.blogspot.ca/2013/10/ca ... -from.html
The bottom line is that the error can be generated because you are using a remote connection while trying to execute a root command. Try using "gksudo". (It worked for me)
strike_back
Thu Jun 02, 2016 7:09 pm
I had the same problem and I was able to find the solution very fast.
"gksudo" workes for me, too.
sunnylyq
Sat Dec 31, 2016 2:20 am
hey, gksudo don't work for me ,but i guess it's about vncserver.
So i stop vncserver an restart it by root,it works!! Maybe it's help to you.
