i've been tinkering with tor on my raspberry pi for a few weeks now. i've got it running tor and torchat, as well as running a web server with a blog (nanoblogger) on the tor network. i've also loaded pidgin with the OTR (Off The Record) encryption plugin. it's also running an XMPP server with both non-tor and (soon) tor connections. i think when i get this all finished and playing nicely (which it seems to be doing) i'll make a SD card image available and call it "Onion-Pi". rather than loading the basic tor package, i found it easier to install Vidalia instead, configure tor the way i wanted to, then copy the torrc to another directory (~/.tor) and run tor from a command line script that also loads arm (instead of Vidalia, because Vidalia periodically hammers the cpu at 80-90% of cpu usage). so when i get all of this the way i want it, i will make an SD card image (minus my own data of course). i have noticed that on the tor network there are at least 6 relays running that have raspberry-pi in the node name, so i'm not alone in being interested in this use of a pi. if anybody is interested in reading the blog on my pi, it can be found at: http://opnju4nyz7wbypme.onion/weblog/index.html and you can holler at me through torchat at khgjyaur2kknp7el
of course, with things getting weird in my country (US), these addresses are subject to change.....
