WhyNine
Voice Bonnet drivers won't install on Raspbian
Wed Feb 10, 2021 9:35 am
I am having problems installed the Voice Bonnet driver, ie it fails. This is on a Pi 3B+.
I have written the latest Raspbian to an SD card, then:
- run "echo "deb https://packages.cloud.google.com/apt aiyprojects-stable main" | sudo tee /etc/apt/sources.list.d/aiyprojects.list"
- run "curl https://packages.cloud.google.com/apt/doc/apt-key.gpg | sudo apt-key add -"
- run "sudo apt update"
- run "sudo apt-get install -y aiy-voicebonnet-soundcard-dkms"
This fails with:
Building initial module for 5.10.11+
Error! Bad return status for module build on kernel: 5.10.11+ (armv7l)
Consult /var/lib/dkms/aiy-voicebonnet-soundcard/3.0/build/make.log for more information.
dpkg: error processing package aiy-voicebonnet-soundcard-dkms (--configure):
 installed aiy-voicebonnet-soundcard-dkms package post-installation script subprocess returned error exit status 10
The first error in the log file is:
/var/lib/dkms/aiy-voicebonnet-soundcard/3.0/build/snd-aiy-voicebonnet.c: In function ‘snd_rpi_aiy_voicebonnet_init
/var/lib/dkms/aiy-voicebonnet-soundcard/3.0/build/snd-aiy-voicebonnet.c:39:43: error: ‘struct snd_soc_pcm_runtime’
 has no member named ‘codec_dai’
  struct snd_soc_component *component = rtd->codec_dai->component;
This used to work (last month?) but somehow is now broken. I have tried doing an upgrade before installed the driver but no difference. I have tried full Raspbian and also Lite with the same result.
What am I doing wrong? Is my Voice Bonnet broken?
Please help!
mongonta
Re: Voice Bonnet drivers won't install on Raspbian
Fri Feb 12, 2021 1:40 pm
I had the same problem.
It seems that VoiceBonnet drivers are only supported up to Kernel 5.4, and I get an error when building dkms that upgrade to Kernel 5.10.
I think the only way for now is to revert to the base OS version.
WhyNine
Fri Feb 12, 2021 5:04 pm
Thanks for the feedback.
Yes, now that I look, I can see that there was a release of raspbian on 12 Jan. I probably originally used the prior release. I'll try using an older version.
If only Google (with all their resources) could keep their drivers up to date ...
WhyNine
Fri Feb 12, 2021 5:29 pm
Spoke too soon. I used a version of raspbian from last year but it still fails at the same point.
How would I "revert to the base OS level"?
mongonta
Sat Feb 13, 2021 12:35 am
I made a mistake. The current release of RaspberryPiOS is Kernel 5.4. I meant to use it without "sudo apt upgrade" during setup.
Also, if you are using VoiceBonnet, AIYProjects OS is also initially Kernel 5.4.
mongonta
Sat Feb 13, 2021 12:47 am
If you are setting up with the GUI, the "Update Software" dialog should be set to "Skip".
WhyNine
Sat Feb 13, 2021 4:30 pm
Ah, right.
I was originally trying to install the driver on stock Raspbian. Using the google image does work, as you say, as long as a blanket upgrade is not done.
Would be interested to know what can/not be upgraded though.
mongonta
Sun Feb 14, 2021 5:50 am
I found out that it works by holding the following 7 packages related to the kernel.
echo "raspberrypi-bootloader hold" | sudo dpkg --set-selections
echo "raspberrypi-kernel hold" | sudo dpkg --set-selections
echo "raspberrypi-kernel-headers hold" | sudo dpkg --set-selections
echo "libraspberrypi0 hold" | sudo dpkg --set-selections
echo "libraspberrypi-bin hold" | sudo dpkg --set-selections
echo "libraspberrypi-dev hold" | sudo dpkg --set-selections
echo "libraspberrypi-doc hold" | sudo dpkg --set-selections
WhyNine
Wed Feb 17, 2021 2:09 pm
I did as you suggested above then an upgrade. Everything still working so it's looking good :D
Many thanks
Return to “AIY Projects”
