syk435
Getting Python input from Webcam?
Fri Jan 18, 2013 6:00 am
Hi, i'm using a sony ps3 eye as webcam input on my pi for an OpenCL python program I'm writing, but for some reason no matter what i do the pi python compiler isn't accessing the webcam. Yet the same code when run on my laptop using the same webcam runs perfectly. Then i checked the usb devices on my pi and it state that "sony playstation 3 eye cam" was on usb port 6. also when using the "motion" package on the pi i was able to use the camera perfectly as input. So my problem is again that the python compiler isn't communicating with my webcam on the pi. Please, think about this and tell me how to fix it; i simply can't think of what's wrong. Here's the sample code I used, and please help me out alll you intelligent guys out there :)
import cv2.cv as cv
#cv.NamedWindow("w1", cv.CV_WINDOW_AUTOSIZE)
camera_index = 0
capture = cv.CaptureFromCAM(camera_index)
while not capture:
print "error opening capture device, correction attempt"
while True:
frame = cv.QueryFrame(capture)
if frame is None:
print "fail with putting in frame"
else:
c = cv.WaitKey(100)
print 'capturing!'
cv.SaveImage("pictest.png",frame)
