hello!
I hope i can find some help here,
I would like to know whether Netgear Wireless Adapter is Compatible with Rassberry Pi (using Ubuntu OS), and also the procedure to make it work !!
Thank you in advance !!
lsusbThe last I heard there wasn't a (decent) build of Ubuntu for the RPi. Has that changed?jameswifi wrote:.... Rassberry Pi (using Ubuntu OS) ...
ndiswrapper is a wrapper around windows x86 driver code, so it believes its running on windows, so that will work on a x86 system, but not on an ARM system. You must use a real (ARM) driver, not a hack.blakegall24 wrote:Ubuntu currently does not support the WNDA3100 adapters but the WNDA3100v1 can work with ubuntu using ndiswrapper
The post you answered is 19 months oldblakegall24 wrote:Ubuntu currently does not support the WNDA3100 adapters but the WNDA3100v1 can work with ubuntu using ndiswrapper
If you read through this (ancient) topic you will see that at no point fruitoftheloom says he actually has ever tried this adapter...shieldsit wrote:fruitoftheloom, have you had any luck getting this adapter working? I have the .9011 as well and I swear I've had it working previously. I guess it could have been a different distro though. Oh well, back to Google I guess!
