ota-kun
Re: Teamspeak server on Pi
Thu Jul 25, 2013 8:12 am
I updated the guide.
I wrote the SSH port for connecting to Teamspeak. *facepalm*
I cleared things up for booting debian.
Out of curiosity did someone get the server running?
b1czu
Mon Aug 05, 2013 11:07 pm
Hi, has anyone mirror for http://198.154.101.186/RaspberryPI/qemudidi2.rar? Because this link isn't working for me.
meigrafd
Thu Aug 08, 2013 11:51 am
b1czu wrote:Hi, has anyone mirror for http://198.154.101.186/RaspberryPI/qemudidi2.rar? Because this link isn't working for me.
Try:
http://199.231.94.230/qemudidi2.rar
But another thing i have to ask:
http://qemu.weilnetz.de/w32/qemu-w32.exe
Doesnt exists anymore and when i try it with some other File like http://qemu.weilnetz.de/w32/qemu-20130616-w32.exe theres no "qemu.exe" in it.. After 2011-10-28 thats missing, but i want to use a QEMU Version as new as possible :(
When i then try it with "qemu-system-i386.exe" i get a strange error: http://www10.pic-upload.de/08.08.13/n5kk79mnyfua.png
Then i tried to overwrite sgabios.bin with http://qemu.weilnetz.de/w32/2012-06-28/sgabios.bin but than the window freeze and crashs :(
Does anyone have a working way / backup?
/EDIT: Got it by using http://www.omledom.com/pub/qemu/qemu-1. ... 2.tar.lzma and added some missing DLL's from ttp://qemu.weilnetz.de/w32/dll/
You can download it ready2go from http://199.231.94.230/
I will also upload a ready2go Debian Lenny and Squeeze Image later
Helaas
Sun Aug 11, 2013 1:12 am
Tried following meigrafd's instructions without success. Well not for now at least. As I understand it, booting up the virtual server can take over 20 minutes?
Anyway. --nographic and -deamonize is not possible on the newest Qemu.
qemu-system-i386 -cpu 486 -hda /home/qemu/debian.img -m 150m -smp 1 -redir tcp:9022::22 -redir udp:9055::9987 -display none -daemonize
Does work however.
Submitted the job that way, going to bed now, see if it's running ok in the morning.
kampari
Fri Oct 18, 2013 9:51 am
- im at step 7 of meigrafd instruction and nothing happens. i have changed the directory and the name of the image
qemu-system-i386 -cpu 486 -hda /home/qemu/debian.img -m 150m -smp 1 -redir tcp:9022::22 -redir udp:9055::9987 --nographic
http://www.bilder-upload.eu/upload/6fd4 ... 089649.png
http://www.bilder-upload.eu/upload/9423 ... 089822.png
- if i use "Helaas step 7"
also nothing
http://www.bilder-upload.eu/upload/38d5 ... 096232.png
- but wenn i only use :
i get en error
qemu-system-i386: could not set up host forwarding rule 'udp:9055::9987'
qemu-system-i386: Device 'user' could not be initialized
sonata82
Wed Oct 23, 2013 6:40 pm
Tried this with qemu 1.6, no luck booting Debian wheezy :(
gymjava
Sat Dec 28, 2013 12:52 pm
I followed the instructions of meigrafd on his site (http://199.231.94.230/), but when i try to connect via ssh to the emulated Debian image, I get this error:
ssh_exchange_identification: Connection closed by remote host
I used
to start qemu.
I think I am stuck on this point.
If somebody has an idea how to connect to the emulated Debian system, please post a reply to help me :D
Koppis
Sun Mar 23, 2014 7:15 pm
I got it running now using a different version of qemu and running with this command:
qemu -cpu 486 -hda debian.img -m 150m -smp 1 -redir tcp:9022::22 -redir udp:9055::9987 --nographic
Booting to the x86 Linux takes about 15 minutes and then I can ssh into it. I can't seem to get teamspeak 3 running however. This is as far as I get and then it just hangs and CPU usage stays at ~97%:
root@qemusqueeze:/home/ts3user/teamspeak3-server_linux-x86# ./ts3server_minimal_runscript.sh
2014-03-23 18:28:31.567552|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.10.3 (2014-01-01 16:28:39)
2014-03-23 18:28:31.989773|INFO    |ServerLibPriv |   | SystemInformation: Linux 2.6.32-5-486 #1 Fri May 10 08:01:28 UTC 2013 i486 Binary: 32bit
2014-03-23 18:28:32.285411|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
2014-03-23 18:28:32.303326|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
2014-03-23 18:28:32.506523|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
2014-03-23 18:28:40.689312|INFO    |SQL           |   | db_CreateTables() tables created
                      I M P O R T A N T
               Server Query Admin Account created
         loginname= "serveradmin", password= ""
2014-03-23 18:29:35.406054|WARNING |Accounting    |   | Unable to find valid license key, falling back to limited functionality
So far it has been running for 45 minutes, I'll leave it overnight and see if I get any errors.
EDIT: It finally launched the server software after 2 hours... But the performance is pretty bad.
jeyt
Thu May 01, 2014 9:49 pm
At step 11, when i type then command and validate, i've QEMU screen and select install (or whatever).
But then, i get a black screen.
What can i do please ?
[Edit]It's OK with QEMU 32bits.
TechKno
Thu May 22, 2014 10:32 pm
Is there anyway you guys could compile an image with the Teamspeak 3 server is already setup?
OllyHayward
Sat May 24, 2014 4:19 pm
I get an error message when i try step 2:
I can't connect to the IP address in the command, what do i do?
BlueShadow<3
Tue Oct 07, 2014 6:39 pm
Just to clarify. This will host a TeamSpeak 3 server. Right? Yes I'm tight and where's the fun in renting one?
Thanks to you all In the fast response!
Thinking of buying a Model B+ soon.
See ya Around!
Shadow.
Shadow<3
meigrafd
Wed Oct 08, 2014 12:14 pm
OllyHayward wrote:I get an error message when i try step 2:
See some Posts above:
Try:
And by the way, still noone got a working Teamspeak running on the PI, also not B+
Kang
Sat Nov 22, 2014 1:35 pm
Hey I've got a question.
The link: 198.154.101.186/RaspberryPI/qemudidi2.rar in the 2. step isn't working anymore so I used this one: http://199.231.94.230/qemudidi2.rar. (This link is working)
And now I got the problem when I try to:
unrar x qemuADLI.part1.rar
And now:
UNRAR 4.10 freeware           Copyright (c) 1993 - 2012 Alexander Roshal
Cannot open qemuADLI.part1.rar
No such file or directory
No files to extract
(I installed the unrar non-free version already)
Can anyone please help me?
luttman
Wed Dec 10, 2014 6:51 pm
Try:
Hey! when i try to make i get
(cd /home/qemu/qemu-1.6.0-rc2/pixman; autoreconf -v --install)
/bin/sh: 1: autoreconf: not found
Makefile:146: recipe for target '/home/qemu/qemu-1.6.0-rc2/pixman/configure' failed
make: *** [/home/qemu/qemu-1.6.0-rc2/pixman/configure] Error 127
im aiming high right now, but can't you uppload a sdcard image of debian with qemu working with your qemu.image_i386_debian.squeeze, i could get you some beer on paypal. :)
ttz91
Mon Mar 23, 2015 4:52 pm
I succeeded to launch TS3 server on qemu on PI.
But I can't access to my server using: 192.168.0.13:9055 from my windows laptop
thank you if you could help
turbo703
Tue Apr 07, 2015 3:08 pm
sorry i don't understand i have my raspberri pi with an os on it in the sd card i installed qemu on it, then you say that i need to make another image.. but if i make this image on another pc what do i have to do then? put the image on the sd and put it in the pi? or ?please help i really want this ts server on my raspberry pi
pUnK
Sun Jan 31, 2016 4:17 pm
There is another emulator for x86 on arm - ExaGear Desktop. It is a bit simpler to use and works 5-10 times faster than QEMU.
Below the link how to install Teamspeak 3 Server on Raspberry Pi using ExaGear Dektop
http://eltechs.com/run-teamspeak-3-serv ... pberry-pi/
ExaGear Desktop - run x86 apps on Raspberry Pi
pUnK from Eltechs
meigrafd
Sat Feb 20, 2016 10:25 am
ExaGear isnt Freeware. Is there a Demo to download?
The more importend question is: does it run stable and with low latency? Only because it "runs" doesnt mean that its usable
pUnK
Mon Feb 22, 2016 12:45 pm
On TS forum here
http://forum.teamspeak.com/threads/4880 ... post416859
there is short feedback
pUnK from Eltechs
DanielWEWO
Wed Sep 07, 2016 5:51 pm
Try:
This link appears to be dead as well, and I'm not willing to pay for exagear. Does anybody have a mirror for qemu?
meigrafd
Wed Sep 07, 2016 9:33 pm
DanielWEWO
Fri Sep 09, 2016 4:22 am
meigrafd wrote:Try: http://199.231.94.230/QEMU/
chears ;)
That link works thanks! I'm wondering if maybe I downloaded the wrong file though? I downloaded qemudidi2.rar and got an error during make.
Makefile:4: ../config-all-devices.mak: No such file or directory
make[1]: *** No rule to make target '../config-all-devices.mak'.  Stop.
Makefile:84: recipe for target 'subdir-libhw64' failed
make: *** [subdir-libhw64] Error 2
I'm not sure if this is because I downloaded the incorrect file or not. Should I try it with qemuADLI.part1/2.rar ?
Edit: I downloaded qemuADLI.part1/2.rar and did the same thing and got this error:
make[1]: *** No rule to make target '/home/pi/raspidev/qemu/vl.c', needed by 'vl.o'.  Stop.
Who is online
Users browsing this forum: No registered users and 6 guests
