gstreeter
apt-get 404 Not Found
Sun Jan 13, 2013 6:25 pm
Anybody else having apt-get update problems as below? Happening on several RPIs:
Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb 404 Not Found [IP: 89.16.177.202 80]
Failed to fetch http://mirrordirector.raspbian.org/rasp ... i1_all.deb 404 Not Found [IP: 89.16.177.202 80]
Jim JKla
Re: apt-get 404 Not Found
Sun Jan 13, 2013 6:29 pm
In a word No ;)
That was froma wheezy image going to load one of my other SD's to check further.
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek ;)
If you find a solution please post it in the wiki the forum dies too quick
gstreeter
Sun Jan 13, 2013 6:43 pm
Ok now, some type of transient problem.
Jim JKla
Sun Jan 13, 2013 6:45 pm
8-) I'd bame the ISP they have broad shoulders and deep wallets. ;)
unclejed613
Mon Jan 14, 2013 1:35 pm
before you blame the ISP, try
apt-get update
then try the install again. i had the same thing happen when i was trying to install something, and the file it couldn't find was out of date.
grynnan
Contact: ICQ Website
Wed Jan 16, 2013 11:49 am
Same issue started today. 404 not found.
Was running fine for months.
(Not the Eth, I'm on the Pi now writing this =P )
plugwash
Wed Jan 16, 2013 11:58 am
When you see 404 errors please run apt-get update. The most likely explanation is that your package lists are out of date compared to what is on the servers.
IF you STILL get errors after running apt-get update please try retriving the files manually with wget and post the complete output of those attempts.
Return to “Raspberry Pi OS”
