Hi all
I just got my model b raspberry pi. Now I have two doubts.
1. Can I use the IPAD2 power adapter as the power source of the PI. The output rated Voltage is 5.1V, output capacity is 2.1A.
Make sure that you use a good quality USB A to MicroUSB cable if you are powering the RPi through the MicroUSB port. Many cheap cables are fakes and have very high resistance causing a large Voltage drop and consequent problems.
