I am not excluding the "Bare Metal" and other groups all I ask is they prepare their own CD that contains all of the software required within the remit of the proposal.
I would personally desire a "Bare Metal" add on
I assume that you are proposing a Pi configuation, not a different HW release. I guess I'm not sure why the specification of both a 4GB SD card and a flash drive for programs. If the bulk of the SW is to reside on the flash drive, then a smaller SD card would make sense. I'm doing all of my learning using a 2GB SD card and the standard Raspbian image. That way I can periodically save off the updated image knowing that I can always expand it to a larger card later. Or, more likely at this point, recover my most recently working image. Interestingly, SD cards of supposedly the same size and same manufacturer are not always the same size. I have an older Sandisk card that is too small to accept the image from my newer Sandisk card even though they are both labeled as 2GB. I've seen this issue in hard drives (different LBA number) but I didn't know it also affected flash devices.Jim JKla wrote:Any more suggestions if you are phobic about adding to the wiki post here.
