bensimmo
Flowchart software (for school age coding)
Mon Dec 14, 2020 3:30 pm
Any recommendations for simple flowcharting software/website I can use.
Just simple coding, senior (11-16) or younger even school level stuff, for school or clubs.
Just need the basic drag and drop part and easy entry
Windows 10 and possibly RaspberryPi OS will be the computers used.
thankyou.
pasdechance
Re: Flowchart software (for school age coding)
Mon Dec 14, 2020 4:13 pm
I think dia is in the repos. With LibreOffice draw you can also make flowcharts. And online they can use Lucidcharts (I think that's what it is called).
Or go oldschool and get some of these.
pasdechance
English/French
Debian, Raspberry Pi OS 64-bit Beta, LibreElec
BMS Doug
Mon Dec 14, 2020 5:57 pm
thankyou.
When you say flowcharting software...
Do you mean software for creating flowcharts?
My interpretation of your post was different from that.
Your post read to me like you meant a simple coding software that you drag and drop blocks of code into and it follows the process. That's Scratch. Free, available for Windoze and Linux (and Raspberry Pi OS).
Scratch for the Pi is able to interface with the GPIO pins.
My apologies if I have misunderstood your requirements.
Doug.
ejolson
Mon Dec 14, 2020 7:28 pm
thankyou.
If the goal is to create documentation about how something works, it's amazing how easy the original graphviz program developed at Bell Labs is to use.
As a teacher there is sometimes a trade-off between software that wears well with continued use versus a simple application too limited to be of use by students who actually master what they were interested in learning.
My belief is that a computerized flowchart tool is most useful if
  • It allows easy revision and tracking of changes using standard version control software such as Git.
    • The input and output of the software can be controlled by another program.
      • It produces publication-quality output that can automatically be embedded into other documents.
      In my opinion any software that doesn't meet the above requirements is a waste of time, particularly for a beginner who needs to invest their efforts wisely to catch up with those who have experience. In particular, rather than learning a limited program now, it might be better to focus on software that has a plausible future use and stick with paper, a stencil and drafting pencil for the flowcharts.
      bensimmo
      Mon Dec 14, 2020 8:05 pm
      thankyou.
      Ah, I mean the good old stencils as posted above.
      Just drag and drop onto a sheet, add a few links, double click in the box and type some text.
      I remember I used Visio a long long time back, a bit of over kill back then.
      I could do it in word or similar too, now that I've been reminded, but thought I would ask see if there is a good simple easy to use software/website.
      Thanks all. I'll check some of them out.
      makerbob
      Tue Jan 05, 2021 8:52 am
      Diagrams.net is my favourite choice for flowcharts. https://app.diagrams.net/
      It's all drag and drop making it simple to use but it has plenty of power too. Sample flowchart attached.
      jonwitts
      Raspberry Pi Certified Educator
      Tue May 18, 2021 9:24 pm
      thankyou.
      Hi Ben,
      I have just been looking at this myself too. I think the easiest thing that is stock-Raspbian is probably LibreOffice Draw... Cross platform and Open Source too, so could be installed on Windows too.
      Jon
      bensimmo
      Wed May 19, 2021 6:36 am
      I ended up using diagrams.net, used it through the NCCE teachcomputing.org certification and other related cpd on futurelearn. Worked well and sharing was easy. Just a bit faffy on the logginging in to Google sometimes. It was easy to pick up and some styling would add extra layer for no reason.
      But easy to sort out.
      I actually haven't looked at LibreOffice Draw lately, must give it a go.
      For what should be a simple stencil style drag n drop, draw a link and type some text, they used to have them back when I did computer studies. Everything seems over complicated now.
      Edit: to add the s
      jonwitts
      Wed May 26, 2021 12:19 pm
      I have installed Dia on our Raspberry Pis; it doesn't look like it has been updated in a while; but then again how many updates does a flow chart editor need? :D
      SonoraTechnical
      Location: Alamos, Sonora, MEX and Green Valley, Arizona, USA
      Fri May 28, 2021 8:26 pm
      I ended up using diagram.net, used it through the NCCE teachcomputing.org certification and other related cpd on futurelearn. Worked well and sharing was easy.
      Just a slight correction... It's diagrams.net Important to add the s... diagram.net takes you to diagram.es which is a provider of Accounting Software near Valencia Spain (I speak spanish so I quickly determined this wasn't the product you were recommending)... ;)
      That said.. Thank you for the link... It's a perfect way to Visualize and Document the 'Flows' that I'm doing in NodeRED on my RaspberryPi... NodeRED reads easy, but allot of times you end up with extensive javascript that calls variables in function nodes so you don't always see the decision tree logic... I'll give Diagrams.net a try for documenting.
      learning never stops...
      Tue Jul 06, 2021 6:28 pm
      In more than forty years of computer programming I have yet to find any use for a drawn flowchart. They aren't used, they aren't useful, it's better to write a solid design spec (which can be included in source for the automatic documentation stuff that's used today).
      For a more definitive opinion, I'd suggest you read Fred Brooks comments on flowcharting in The Mythical Man Month.
      Partially quoted here: https://en.wikiquote.org/wiki/Fred_Brooks
      http://www.cesarkallas.net/arquivos/liv ... dition.pdf Chapter 16.
      Languages using left-hand whitespace for syntax are ridiculous
      DMs sent on Twitter/LinkedIn will be answered next month.
      The use of crystal balls and mind reading is prohibited.
      SonoraTechnical
      Fri Jul 30, 2021 2:35 am
      Thank you for the anecdote. My mileage differs, as may that of others.
      Flowcharts are a good 'implementation agnostic' gateway to programing using IEC-61131 function block programming in a variety of vendor products. The also help folks to understand complex workflows. Several of my large clients use flow charts to document all of their process maps and work instructions for their ISO-9001 and ISO-14000 certification efforts.
      I have used function block diagrams as an alternative to ladder logic diagrams in a few Rockwell Automation Control Logix and Compact Logix projects. Lots of vendors have used Function Block Programming (Opto22 Ultimate and PAC controllers, Allen Bradley Servo Force, Kinetix, other stepper motor control software) and a flow chart is often a good way to get user input to craft a good functional spec before beginning a project or set of instructions before tackling a particular problem. I'll even do a small flow chart even before tackling a particularly difficult Transact-SQL stored procedure in SQL or a fun little Node-RED project on a PI.
      Anyway, thank you for the references. I'll look at a few of them.
      Sun Aug 01, 2021 11:53 am
      Back in 1974 when we were being taught computing in BASC we were also introduced to the concepts of structured programming and flow charts.
      Thing was BASIC had little in support of structured programming back then. As in proper conditional blocks and so on. So if one were just diving into writing code to solve a problem it was easy to end up with a tangled mess of GOTOs. Putting some thought into how to structure the code with a flow chart design first helped get thing organised.
      We were also introduced to assembly language, a flow chart design first was helpful there as well.
      The following year I discovered ALGOL. So never felt the need for a flow chart again.
      Except... in the early 80s a military radar project I worked on required flow charts, structure charts, and a pile of design documents before even writing one line of actual code.
      Now a days graphical programming languages like Scratch essentially present the same structured programming as our flow charts did but with somewhat different symbols and more rigorously.
      As for Fred Brooks and his flow charts vs tables suggestion.... Often I don't have any tables either :)
      Return to “Teaching and learning resources”
