Have set up Config file for upstairs TV (Ferguson F2206LVD, 22" HD Ready LCD) and successfully made connection thro HDMI input.
Config File as follows :-
hdmi_group=1
hdmi_mode=19
hdmi_drive=2
# Group 1 for HDTV, Mode 19 for 720P 50 Hz., Drive 2 for HDMI voltage and audio
But have no success with main TV downstairs (Philips 32 PF 7520D/10 HD Ready LCD). This TV has only DVI input so I use an adaptor plug to connect HDMI cable. First tried tis config file:-
hdmi_group=1
hdmi_mode=20
hdmi_drive=1
# Group 1 for HDTV, Mode 20 for 1080i 50 Hz., Drive 1 for DVI voltage and no audio
Did not work so tried all sorts including no config file. Message on screen either "no input signal" or "format not supported".
Connection with composite video works ok.
I have noticed on other TV that if cable not connected at startup then connecting cable later does not work. On this TV it defaults to "TV" source so I switch on RasPI then change source to either "HD" or "PC" (not sure what the difference). Could the TV be missing some important start up data.
Any ideas would be welcome, I will try them and report back.
Regards
